Tranny Troubles
Old Aug 11, 2002 | 09:22 PM
Dedalus2k's Avatar
Dedalus2k
Default Tranny Troubles
94 Integra RS - Over the course of the last few weeks it has become more difficult more often to get shift into first gear. Sometimes it simply won't go in. If I shift it into second, without engaging the clutch, then back into first it slides in fine...usually. But this afternoon, I had my first instance of it not going into second. All the other gears shift a touch rough too. One friend says it's just the master cylinder and another said it's time for a new tranny... What's your verdict?
Old Aug 11, 2002 | 09:25 PM
AP2's Avatar
AP2
Moderator Alumni
It may be signs your clutch is going south. How old is it?
Old Aug 11, 2002 | 09:28 PM
Dedalus2k's Avatar
Dedalus2k
Clutch is just six months old - Exedy Organic Racing Clutch
Shoulda mentioned that...sry.
Old Aug 11, 2002 | 09:29 PM
AP2's Avatar
AP2
Moderator Alumni
What kind of tranny fluid are you using?
Old Aug 11, 2002 | 09:36 PM
Dedalus2k's Avatar
Dedalus2k
It's a manual...had it done. :nono: Feeling lazy that day, so I don't know what they put in it.
Old Aug 11, 2002 | 09:37 PM
AP2's Avatar
AP2
Moderator Alumni
That may be the case. I wouldn't rely on 10-30w syn. oil a few people use in their Honda trannies.... At first I was thinking you might have popped a spring in the clutch but then you just put in a new one so it may be the tranny fluid.
Old Aug 11, 2002 | 09:39 PM
Dedalus2k's Avatar
Dedalus2k
What's a good method of changing it without getting it all over myself and the driveway...
Old Aug 11, 2002 | 09:40 PM
AP2's Avatar
AP2
Moderator Alumni
Buy yourself some sort of catch pan if you're going to drain it. And buy a pump with a long enough tube to stick in the hole where you add the tranny fluid.
Old Aug 11, 2002 | 09:42 PM
Dedalus2k's Avatar
Dedalus2k
If that isn't it...is it possible the master cyl is going? My friend says it isn't disengaging all the way and gets jammed up. How much are they to have changed...I don't wanna deal with bleeding the lines and all that.
Thanks for the help man...I'll try changing the fluid tomorrow.
Old Aug 11, 2002 | 10:42 PM
reech-around's Avatar
reech-around
RIP Woong.
it does sound like the master is going. i cant remember exactly, but i paid about $120 for a new master and slave (parts only).
CrJenkins13
5
Feb 25, 2007 09:55 AM
SumAccordGuy94
Accord
Dec 16, 2002 02:54 AM
b00gers
8
Dec 4, 2002 08:10 PM
eclipse spanker
13
Oct 10, 2002 09:17 AM
xtrmcheeze
17
Jul 15, 2002 01:32 PM
