when do you replace your rotors?
Old Jul 16, 2004 | 03:17 PM
1CleanLS's Avatar
1CleanLS
Default when do you replace your rotors?
Hey I'm just curious on how you can determine whether or not your rotors need to be changed.
Also, do you think its a good idea to get aftermarket rotors?
Old Jul 16, 2004 | 03:27 PM
LT's Avatar
LT
The deer had to die!
rotors need replacement just about every 60K miles. but it depends on how they were cared for (ie if the pads got real low and started to "eat" the rotor). if they are too thin, they will need replacement, if they have grooves that can't be machined safely -REPLACE!, also if they are warped beyond repair -REPLACE!
Autozone has good blanks for cheap. you can get Brembo blanks online for $30 each.
Old Jul 16, 2004 | 03:38 PM
crazydriver27's Avatar
crazydriver27
crazydriver27
I have Brembo after market rotors. looks good
cross drilled rotors!
Old Jul 16, 2004 | 09:03 PM
ls_101's Avatar
ls_101
integra fs
if u replace one side u have to do the other side, on the inside of the rotor there is a number by the bolt pattern, measure, with a caliper gauge and if its smaller then that they cannot be turned and must be replaced
Old Jul 18, 2004 | 04:29 AM
Kai's Avatar
Kai
Rotorphile.
Oh, about 100k or you screw them up, whichever comes first.
My car is riding on the stock rotors, which are just about to be replaced... with nearly 150k on them.
Old Jul 18, 2004 | 06:38 AM
ISP James's Avatar
ISP James
DAMIMRED
i have brembo blanks... they are nice but i wouldnt say i have any extra benefit over regular OE replacement rotors... so my .02 says no need for fancy named blanks... if you want to start talking about cross drilled or slotted... well thats another discussion
Old Jul 19, 2004 | 02:50 AM
Kai's Avatar
Kai
Rotorphile.
i have brembo blanks... (...) so my .02 says no need for fancy named blanks
The funny thing is, Brembo blanks are the cheapest rotors I know of... fancy brand name or not.
Old Jul 19, 2004 | 12:32 PM
Tobra's Avatar
Tobra
I have my original rotors at 116,000. I just put my first new pads on a few thousand miles ago. Rotors need to be replaced when they are too damaged or thin to be machined/turned
Old Jul 19, 2004 | 06:56 PM
timmy8151's Avatar
timmy8151
Correct.
I'd recommend just getting some blank rotors, like the one's made by Autozone. There's no need to get slotted or cross drilled rotors.
Old Jul 20, 2004 | 04:58 PM
Tobra's Avatar
Tobra
You will also be much less likely to warp a rotor if you use a torque wrench to put your lug nuts on. If the nuts are tightened unevenly, it sort of twists the rotor and will accelerate the need to spend money. I am a cheap MOFO
