susp help.
Old Aug 10, 2002 | 08:39 PM
b00gers's Avatar
b00gers
Default susp help.
i know this has been asked over and over again....
but i get a lot of squeaks from my suspension. its all stock except for the Ground Control adjustable springs and KYB AGX shocks, along with Ingalls camber kit with rubber bushings.
one thing ive noticed is the noise get extremely louder when its hot outside, or when the car is warmed up. theres hardly any noise the first 5-10mins of driving.
this only occur when im going over potholes or over a speedbump or driveway.
one thing i thought of is the bushings. so im thinking i should just lube everything and see if that helps.
so now what i need to know is what type of lube, and how to lube it. also if you have any other causes please post.
thanks a lot
Old Aug 11, 2002 | 03:29 PM
b00gers's Avatar
b00gers
its still making noise....
help. =D
Old Aug 11, 2002 | 06:50 PM
evo119's Avatar
evo119
GO GIANTS!
yeah...i'm pretty sure it's the bushings...they're known for that...
As for lube try some Ky
Old Aug 11, 2002 | 08:24 PM
b00gers's Avatar
b00gers
aare you serious about the KY?
Old Aug 12, 2002 | 07:45 AM
reech-around's Avatar
reech-around
RIP Woong.
silicone spray works pretty good. u may have to reapply it every so often though.
Old Aug 12, 2002 | 08:48 AM
Shingoblade-GSR's Avatar
Shingoblade-GSR
Hellsing Agency
Ground control coilovers sleeves clank on my teg; not sure if that's what you're hearing.
Shingo
Old Aug 12, 2002 | 08:54 AM
reech-around
RIP Woong.
if u get that clank noise, it's probably the coils on the spring touching each other when it compresses. i wrapped my h&r race springs with rubber wire wrap (wound in a spiral) from the hardware store.
Old Aug 12, 2002 | 09:12 AM
ur31337's Avatar
ur31337
Colby
Will, my suspension does the same thing. It's all stock though.
I gave up on figuring it out, because it's only over speedbumps really. I come across maybe one or two a week.
Old Aug 12, 2002 | 10:52 AM
b00gers's Avatar
b00gers
if its all stock i would take it to the dealer...its really annoying.^
rich, so the spray stuff, do i need to take out the bushings? or just spray in the area while everythings intact?
Old Aug 12, 2002 | 11:20 AM
reech-around
RIP Woong.
just try spraying them as they are. hopefully the lube will seep its way in.
96BLKGSR
3
Apr 1, 2006 09:29 PM
b00gers
11
Jul 1, 2003 12:32 PM
b00gers
Jun 29, 2003 02:13 PM
b00gers
Jun 26, 2003 12:48 PM
DrugTeg
Jul 17, 2002 08:40 PM
