A few ?? for Hondata owners.....
I am looking into getting the Hondata S200. It seems to have the additional features I want that is not available with a VAFC. I know some of you are running this. I would appreciate some feedback and suggestions.
What system are you running and with what mods?
Did you install and tune yourself?
Did you purchase from a dealer or from Hondata?
What other Management or piggyback systems have you ran in the past?
I will more than likely have it installed by someone who knows what they are doing (not me). There are NO DEALERS in my area. closest in NY I think.
Tuned by Steve Sakai.
SMSP header and exhaust, front to back.
Very mild flow work on the head. Comptech Icebox.
The car's a delight to drive on the street and still gets right up against 30 miles per gallon.
Hondata has infinitely more to offer than a VAFC. First and foremost independent control over timing and fuel..with VAFC, every adjustment to the fuel % affects timing..very dangerous..also you get a factory Honda ECU with 20 years of Honda engineering behind it, try to beat that with a little variable resistor like the VAFC...factory injector drivers..you can't beat the idle..and as Knighton said..30+ mpg, even out of my 295whp turbo car..btw I tried the VAFC for a year..It was fun to play with...but you get tired of playing with it to get your car to run and idle...
I installed it myself in less than 20 minutes. My tuner gave me a chip with a very good base map, so I was able to drive it to his facility without issues. The car made 240whp on the first pull without changing the base map...not too bad.
Originally Posted by captainzorg
Did you purchase a Modified ECU form Hondata? or did you use the Factory ECU? I have to get a cable to convert from OBD2 to OBD1 ($250) or a OBD1 ECU for $250. Is this correct?
I did not need any kind of conversion.
Call Hondata and just ask them. They are very good w/customer service. They can also suggest someone in your area to tune it.
http://hondata.com/vehicles.html -
Integra Type R 97-01 US B18C5 P73 P72,P28,P30,P61,P08J,P30J,P72J 2,6,7
2 - Manual transmission only with the s100 or s200 systems.
6 - OBDII to OBDI adapter harness required
7 - OBDI ECU swap
7 - OBDI ECU swap
