Axle problem
My 2001 type r keeps eating the driverside cv axle. I replaced it 3 times and it goes bad after about 400 miles. Anyone know what might be wrong? Drives great after the new axle is installed but then goes bad and the whole car shakes.all the motor mounts look good i think and the balljoints and wheel bearings seem fine too.Its been doing this since i hit a pothole months ago.Its the outer part of the shaft that goes into the wheel that goes bad.
the wheel bearing could be causing it, but it is more likely a geometry problem caused by your pothole incident...check all bushings in the arm, the shock, shock mount, alignment, and double check all engine mounts.
The shaking sounds more like a tie rod, more then anything....if it was the bearings, its usually more of a whiring noise you hear like from a big [...] truck
Last edited by George Knighton; Jul 13, 2004 at 04:42 AM. Reason: Removed pejorative class identifier.
Originally Posted by steven zipkin
the motor mounts were bad thanks
Glad you got it fixed, anyway.
