maint. required code? help please 96 gsr
Old Jun 21, 2004 | 12:33 AM
DavE96GsR's Avatar
DavE96GsR
Default maint. required code? help please 96 gsr
hi i have a 96 gsr and i turned my car on and the maint. required light comes on for about 1-3 secs then flashes 10 times after that...i kno i need a new alternator belt and am wondering if it has anything to do with that?
if not could anyone please help me out...i have a article on integra codes somewhere showing which codes mean which problems but i cant seem to find it right now....
thanks,
dave
Old Jun 21, 2004 | 07:28 AM
kfar09's Avatar
kfar09
if it just blinks and then goes off, that is just telling you that it is time to change your oil. There is a button under the steering column that if you hold it down while turning on the car, it will reset the light.
Old Jun 21, 2004 | 10:12 AM
BONE's Avatar
BONE
exactly what kfar09 said but if you reset it press and hold the button in, turn on the ignition and count to 10 the light should go out if it doesn't repeat the steps intil it does hope this helps
Old Jun 21, 2004 | 11:58 AM
Kha's Avatar
Kha
eliteness hit me
you jiggle the key like 5 times and honk the horn 4 times, and step on the gas 3 times, brakes twice, and then pull the ebrake up.
heh
hold the reset button bro :P
Old Jun 21, 2004 | 11:59 AM
Kha's Avatar
Kha
eliteness hit me
its under the steering column, you'll feel it, just hold it down for a bit when you first turn the engine on.. and its blink and go off.
Old Jun 21, 2004 | 12:18 PM
DavE96GsR's Avatar
DavE96GsR
ya i had it turned off before / unpugged but then i reset it...so if it blinks 10 times then its just the oil ? i was under the impression that different blink sequences like say, it blinks 6 times then its a certain problem and if it blinks say 3 times its another probloem...
thanks!
dave
Old Jun 21, 2004 | 12:59 PM
JimBlake's Avatar
JimBlake
The 'check-engine' light blinks out a code when you connect a jumper across a service connector. That comes from the ECU actually measuring some kind of problem.
The 'maintenance required' light is just connected to an odometer. It's not only oil, but your entire maintenance schedule is based on 7500 mile intervals. It starts blinking a few hundred miles early to warn you. It'll come on solid 7500 miles after it was last reset.
