brakes..........
Old Jun 18, 2004 | 11:27 AM
R34Lude's Avatar
R34Lude
96teg
Default brakes..........
My 96 integra was making a metal scraping noise from the driver side. I took off the rim and there was some green grease all over the back of the rim...DOes anyone know what the problem is?? and how to fix it?
Old Jun 21, 2004 | 08:32 PM
teg_fan's Avatar
teg_fan
I like integra's
Either your pads are low, or your dust cover is rubbing up against the rim. My dust cover was rubbing for a while, I think either I, or a shop might have bumped it too hard puttin on and taking off the wheels.
Old Jun 21, 2004 | 10:12 PM
Daniel's Avatar
Daniel
Green grease? Hmmm. Wonder if you have a radiator leak and it's just blowing on the back of the wheel. Is there anything green anywhere else?
If there's grease, you may also have a busted brake line. Can you find a source for the grease and get back to us?
Old Jun 22, 2004 | 02:12 PM
XSrcing's Avatar
XSrcing
green colored grease on the wheel is from a cracked CV boot. the scraping noise i most likely low pads.
Old Jun 23, 2004 | 05:49 AM
R34Lude's Avatar
R34Lude
96teg
How much is it to replace a cv boot at the shop and how much is it if i replace it myself? I think it is a cracked cv boot. I looked behind the rotor and it does look like there is a crack on the cv boot, but then i peeled the little rusted metal off and it didn't look cracked anymore. So i'm not sure..I made sure that i tighten the wheel and it stoped make a loud scraping noise but still makes a quiet noise of scraping.
Old Jun 23, 2004 | 06:06 AM
teg_fan's Avatar
teg_fan
I like integra's
If it is cracked, and all the grease came out, then your cv joint might also be bad, depending on how long its not been lubed
Old Jun 24, 2004 | 10:44 PM
XSrcing's Avatar
XSrcing
i dont know how much the shop you go to would charge, but at the dealership where i work it is 1.5 hours labor plus about $25 in parts.
jordan88
92+ Civic/EL & Del Sol
16
Jan 19, 2004 05:06 PM
brtecson
Oct 1, 2003 05:26 AM
NoRiCeHeRe
3
Jul 11, 2003 12:32 PM
Mistuda
CRX & Pre 92 Civic
8
Apr 27, 2003 10:52 PM
slipspeed
CRX & Pre 92 Civic
Sep 19, 2002 02:22 PM
