short ram VS. cold air
Old Jun 17, 2004 | 07:15 AM
yourmom25's Avatar
yourmom25
CAI will give you the "AEM hump" in the middle of your powerband, while it guts your low-end power and has no difference in the top-end. The SRI will give you better throttle response than the CAI simply because it's a shorter pipe which facilitates faster air flow. Less bends also helps with the flow. Don't get a CAI. AEM lied to you with "10-15hp gains;" that's bullshit.
The only advantage the CAI has over the SRI is that it sucks in cold air. True, cooler air leads to a denser air mix, which translates to more oxygen for your car to burn. However, when your car is travelling at 20mph or above, the air that's flowing through your engine bay will keep the air as cool inside as it is outside. If you're really paranoid about warmer air with an SRI, get a Comptech Icebox or if you're on a budget make a DIY heat shield over the filter. Those two options are the best compromises for power.
People who tell you their CAI made their car faster are using their butt dyno. It's been proven that the CAI does very little in terms of performance compared to the SRI.
Finally for those people who still think their CAI is hella awesome, the hydrolocking tendencies of the CAI can be avoided with a bypass valve. Good call.
Old Jun 17, 2004 | 07:59 AM
Epoch's Avatar
Epoch
CHRISTMASTIME IN IRAQ
:werd: Thank you.
Old Jun 17, 2004 | 03:02 PM
tommy1223's Avatar
tommy1223
speaking of the DIY heat shield for the intake, how do u make that? i've been looking everywhere for steps on how to build that and havent found it yet.
anyone want to link me if they know?
THANKS
Old Jun 17, 2004 | 06:41 PM
XSrcing's Avatar
XSrcing
THANKS
just get some thin sheets of aluminum or sheet metal and bend it till it fits tight. no real instructions, just the "make it work" kind of deal.
Old Jun 17, 2004 | 10:59 PM
tommy1223's Avatar
tommy1223
but wouldnt the metal absorb heat over time and defeat the heat sheilding purpose? or is there some kind of heat spray i need to spray on it
Old Jun 17, 2004 | 11:47 PM
Epoch's Avatar
Epoch
That's why heat shields work... not enough metal to absorb large amounts of heat, and so it reflects most of it back.
Old Jun 19, 2004 | 12:51 PM
ansay's Avatar
ansay
i heard a lot about the ice box system...supposed to give good gains and incorperate features of both the cold air and short ram systems. im really lookin at this product...only thing is its kinda on the expensive side. although there is a DIY kit out there...good luck in your build
alohas
Old Jun 19, 2004 | 11:43 PM
tegryder23's Avatar
tegryder23
cgp dc4
I have a SRI and I love it, just depends on where you live. An intake wont give u any noticeable power gains but definatly a deeper sound with the SRI. If you live in a rainy state like me get a bypass even though the chances of sucking up water are slim cuz its pretty hard, it can still happen, I'd gow ith the SRI www.dragracing.com has them for 75 bucks and great service thats where i got mine. Good luck!!
Old Jun 20, 2004 | 02:15 PM
yourmom25's Avatar
yourmom25
Nah that $75 is still too much. Go with an ebay intake and put a K&N filter on it. All other systems show negligible gains/losses. The ebay one may run you $30-40 max. Just make sure to ask that the diameter of the pipe is 3".
Old Jun 22, 2004 | 08:19 AM
CrazyAzn's Avatar
CrazyAzn
GSR fanatic
hey man.. i will sell u my used CAI... i have an 01 gsr also... but took it off..sell it real cheap too...let me kno..
