Unable to remove spark plug
Old May 14, 2004 | 10:22 AM
GripIt&RipIt's Avatar
GripIt&RipIt
Default Unable to remove spark plug
The last time I had my plugs replaced the mechanic said he was unable to remove one of them. I suppose it was basically stuck. He said to remove it would require some other means which I don't recall. Can someone please elaborate? What are the implications of this?
Old May 14, 2004 | 10:30 AM
9600baud's Avatar
9600baud
JDM rox ur world
:eek3: did they seize in the block? damn... thats gotta suck
Old May 14, 2004 | 11:07 AM
LT's Avatar
LT
The deer had to die!
if the plug is seized into the head, and there is no way to break it loose, the only thing i can think of is pulling the head off and basically drilling it out.
Old May 14, 2004 | 01:01 PM
GripIt&RipIt
I don't do any repairs to my car, so how involved would it be to drill it out?
Old May 14, 2004 | 01:34 PM
LT's Avatar
LT
very, the head of the engine would be removed from the block, then the plug would be drilled out, and the head reattached to the block - good opportunity to replace the headgasket.
Old May 14, 2004 | 04:44 PM
newgsrdriver's Avatar
newgsrdriver
I would say first things first, soak the shit out of it with WD40, PBBlaster, Silicone Spray, whatever you have.
If you cant loosen it with a ratchet, slide a pipe over the end of the ratchet for more leverage. If its stripped, itll just spin. If its stuck, you have to be able to get it out. Worse comes to worse you get the ratchet, extension, a long pipe and a hammer...itll come out.
Old May 15, 2004 | 07:13 AM
c_rogue69's Avatar
c_rogue69
wtf goes here?
If all else fails, get a bigger hammer...
Old May 18, 2004 | 09:02 AM
fjm1's Avatar
fjm1
G35
Along with the anti seize and plenty of leverage posted above, make sure your using a deep well six sided socket so it doesn't round out on you.
If it's already rounded, Sears sell really great extractors. Better than others because the top allows the tip of the plug to pass through a hole instead of having to bust off the top of the plug and possibly get debris down into cylinder.
Old May 18, 2004 | 09:22 AM
hondatech's Avatar
hondatech
Honda tech/eprom hackr
Good luck, i busted off one on a vintage N600 motor once and had to pull the head. It messed up the hole pretty good.
I would just go for it and if it breaks so be it. At least in the end you'll have fixed it. Next time make sure anti-seize gets on the new plugs.
ZiviCase10287
92+ Civic/EL & Del Sol
11
Feb 18, 2004 02:33 PM
honura
5
Jan 23, 2004 09:34 AM
vassil3427
Accord
8
Dec 20, 2003 10:39 PM
wayne99integra
Engine Swaps, Tech & Tuning
3
Nov 25, 2003 12:05 PM
stephan
Do It Yourself
2
Feb 19, 2003 05:32 PM
