ABS pump died
Old May 13, 2004 | 12:12 PM
Anthony's Avatar
Anthony
ZOMG Pew Pew Laserbeams
Default ABS pump died
ok so my abs pump died and my mechanic it would be 2k+ with labor and parts so i just pulled all the fuses and am not using it anymore. any benefits or problems if i do this?
Old May 13, 2004 | 10:57 PM
Anthony's Avatar
Anthony
also is the price he quoted me with correct?
Old May 14, 2004 | 03:44 AM
tucker8235's Avatar
tucker8235
My abs light is on. Is that what happens when the pump goes out? How about parts from a junkyard? I bet that would be a lot cheaper. 2K sounds like a lot.
Old May 14, 2004 | 06:51 AM
emry5treasure's Avatar
emry5treasure
I had an acura tech quote me $300-$500 just to diagnose what was wrong with mine. It wouldn't surprise me, labor included, that a new ABS unit installed would run 2K. I don't think there are any benefits to disconnecting the power to the ABS motor. The biggest problem with not having ABS is safety. There are lots of cars made without ABS, but its nice to have...
Old May 14, 2004 | 09:21 AM
ragerized's Avatar
ragerized
dc4 ownerages
id rip it out
Old May 14, 2004 | 09:44 AM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
The ABS system has a control unit just like the engine does. There's a way to pull a code from the control unit, however off the top of my head I couldn't tell you how because I only know the procedure for '90-'93 cars.
You certainly don't need to pay $300 just to have it diagnosed. Now if only someone with a shop manual for a '94 or newer car shows up...
Old May 14, 2004 | 10:10 AM
Anthony's Avatar
Anthony
i don't really think i want to change parts from a junk yard, the labor of installing it just seems to extensive to warrant having it on a car who's value is only about double that. the abs might be on if the fuses are blown or not working in the ABS relay box
Old May 14, 2004 | 01:14 PM
LT's Avatar
LT
The deer had to die!
taken from my 94 Integra Helms:
Old May 14, 2004 | 03:00 PM
Anthony's Avatar
Anthony
mine died it was leaking fluid out everywhere underneath my car
Old May 15, 2004 | 09:05 AM
LT's Avatar
LT
just take it out, you'll save weight!
