camber question
Old May 9, 2004 | 08:36 AM
chahsiubow's Avatar
chahsiubow
Default camber question
Can I use "Ingalls front adjustable camber kit, part number 3572. Allows +1.25 to +3 degree adjustment" To fix a -1 degree camber on my right front? Or do I need the other one that fixes -3/4 degrees to +1 degree pn#3570?
#'s for my front camber are: (left) -27/32 degrees and (right) 17/32 degrees.
Old May 9, 2004 | 09:26 AM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
Either one will work. To get rid of one degree of negative camber, you need to add one degree of positive camber.
However those numbers are still within factory spec so you don't really need to do anything.
Old May 9, 2004 | 09:42 AM
chahsiubow's Avatar
chahsiubow
From what the mechanic told me when he did my alignment, the right side is off 1 degree empty and 2 degrees when i hop in. My tires show obvious camber wear. How long and to what extent will my tires wear out? I drive my car everyday about 2 ten minute rides. Average about 1000 miles a month.
Old May 9, 2004 | 10:11 AM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
How long your tires will last depends on what kind of tires they are and how often you rotate them. It'd be a good idea to rotate them now if you're already seeing some uneven wear from the camber.
Old May 9, 2004 | 12:25 PM
b00gers's Avatar
b00gers
that "camber wear" from your tires can also be from a bad toe alignment. what are your numbers for those?
Old May 9, 2004 | 01:48 PM
ISP James's Avatar
ISP James
DAMIMRED
i have an ingalls camber kit i never installed i can sell you, ill even meet you halfway between bing and utica to give it to you. i want to get the SPC adjustable ball joints.
Old May 9, 2004 | 08:34 PM
chahsiubow's Avatar
chahsiubow
my toe is fine, it's 0, 0 now, and wasn't too off before alignment.
BreaKnBarrierz8
92+ Civic/EL & Del Sol
29
Apr 6, 2005 07:57 PM
c_rogue69
11
Apr 13, 2004 03:48 PM
kid018
Accord
5
Jul 10, 2003 11:47 AM
matvtec
4
Aug 22, 2002 07:08 PM
G2Integrity
4
Jul 6, 2002 10:40 PM
