Camber Kit Required 1.75/1.5 Drop?
Old Apr 8, 2004 | 12:32 PM
newgsrdriver's Avatar
newgsrdriver
This is how you know if you need a kit:
1) Install suspension
2) Let settle
3) Go get an alignment, make sure they correct your toe.
4) They will give you a printout with your camber/caster/toe #'s. Look at that. If right off the bat its -3 or more, you may as well get a camber kit because depending on your tire size/characteristics, youre going to be rotating way too frequently and its just going to wear prematurely anyway.
5) If its a reasonable # (mine is ~-2.6 if I remember right, which is pretty bad) then drive on them. Monitor your wear closely. When you see it start to wear on the inside a bit more, rotate your tires. If the new set on the fronts then wears uneven again in an unreasonable amt of time, you need a camber kit or you're SOL.
Old Apr 8, 2004 | 01:13 PM
ISP James's Avatar
ISP James
DAMIMRED
Originally Posted by WiLL
y o o
refers back to the user yoolykeme.
ahahhahahah :rofl: hahahah they censor that for him? freaking amazing hahahahahah
i got a camber kit for my setup, my buddy is an acura tech in syracuse and he told me to expect 1 degree per inch lower i go... i have the same setup that you're getting 1.75f/1.5R i might be able to let you know exactly how it goes for me once i get the parts outta my trunk and onto my car
Old Apr 8, 2004 | 02:13 PM
DVPGSR's Avatar
DVPGSR
I need sleep...
An alignment is always key when dropping the car. I have H&R Sports which is the same drop and so far have not had any abnormal wear on my tires front or back.
98WhtCivicEx
Do It Yourself
7
Apr 9, 2004 07:05 PM
Spec R
2
Jun 8, 2003 08:05 PM
HLD_Civic
92+ Civic/EL & Del Sol
9
Dec 15, 2002 03:09 PM
KMFDM
Accord
21
Oct 21, 2002 06:30 PM
