Mobil 0w-20
Mobil 0w-20
I found this on the Mobil 1 website.
"Product Description
Mobil 1 0W-20, Power and Performance Formula, is the most advanced performance synthetic engine oil designed to provide the ultimate level of power, and protection to keep engines running smoothly and cleanly. Mobil 1 0W-20 exceeds the requirements of the latest gasoline and diesel powered automobile engines. Mobil 1 0W-20 is the ideal product for high revolution and output four and six cylinder cars where a 0W-20 or 5W-20 viscosity lubricant is recommended."
So I should be able to use 0w-20 in my GSR since Honda/Acura dealers use 5w-20 right? By the way, I live in the Bay Area, Ca if weather plays a role. I did a search and I found this topic about TL's. Just wanted to know if it was the same for integras.
Originally Posted by DVPGSR
I use mobil-1 5w-30 and have been very pleased with it.
Stick with 5w-30, or 10w-30 the only other oil i have used was 10w-40 and that was in the summer when its 100-110 degrees here...
They use the lighter grade(0W-20) oil in the hopes that they will eke out a bit more fuel economy, due to reduced drag on the engine. It would probably be okay to use the light oil in your car, but I have never been one to tempt fate, stick with 5W-30 like it says in your owner's manual, I have used mobil 1 for about 100k miles and been happy
U put oil that thin in your car and it will probobly start buring out the tail pipe!!,
use only 5wXX or 10wXX unless u live in antarctica!!. I used 5W30 for the first 60K, and after that it was starting to burn a quart every 2-3 weeks, so I switched to 10w30 and the problem dissapeared!
Wait wait wait...you can stop your car from buring oil by using a thicker oil??...my girlfreinds izuzu trooper (aka POS) burns oil like crazy...it takes 10w-30, would upping it to say...somthing like (i dont even know if it exists) 20w-50 or somthing get it to stop? or maybe is that to thick
Rotorphile.
It will slow the oil burning and quiet the valvetrain though.
