Hydraulic Jack
Old Mar 8, 2004 | 04:51 PM
nsxtasy
Guest
Posts: n/a
So what's the difference between the $200 HF jack, the $130 HF jack, and the $90 HF jack?
Old Mar 8, 2004 | 09:22 PM
jiahanhao's Avatar
jiahanhao
the lifting height, and the number of pumps required to get to that height (gear ratio? =P)
Old Mar 9, 2004 | 06:35 AM
mstewar's Avatar
mstewar
Originally Posted by nsxtasy
[quote:0ec0a9f4e7="mstewar"]drive your car onto blocks of wood, then jack it up..
That technique only helps if the minimum lifting height is not low enough, and does not affect the maximum lifting height.[/quote:0ec0a9f4e7]
the guy said his car was too low for a specific jack..
i gave him a suggestion that allows him to pick out any jack..
Old Mar 9, 2004 | 04:42 PM
nsxtasy
Guest
Posts: n/a
Aha! You're right. Sorry... ops:
Old Mar 12, 2004 | 02:25 AM
BudMan
Guest
Posts: n/a
Min & max height are the major differences between the jacks. They will all life our cars.
Old Mar 12, 2004 | 06:10 AM
nsxtasy
Guest
Posts: n/a
Looks like the handles are longer, too, and some other dimensions are different.
Just to summarize:
$89.99 Harbor Freight Item 91039-1VGA
Minimum saddle height: 3''
Maximum saddle height: 15-1/8''
Handle overall length: 23''
Two piece knurled aluminum handle prevents slipping
Overall dimensions: 20-1/2" L x 9-3/8" W x 8" H
$129.99 Harbor Freight Item 47246-9VGA
Minimum saddle height: 3-1/2''
Maximum saddle height: 17-1/2''
Hydraulic lift: 14''
Handle overall length: 47-1/4''
Pumps for maximum height: 6
Overall dimensions: 23.62'' L x 11.81''W x 6.1''H
Tool weight: 35.40 lbs.
$199.99 Harbor Freight Item 2672-5VGA
Minimum saddle height: 4''
Maximum saddle height: 19''
Pumps for maximum height: 5
Overall dimensions: 26"L x 13"W
Non-marring industrial grade nylon wheels turn on heavy duty 5/8" diameter axles
Two fixed wheels in front: 2-1/4" x 2" , two swivel wheels in rear: 1-7/8" x 1-3/8"
Tool weight: 55.0 lbs.
