What Should I Buy
Old Feb 29, 2004 | 12:50 PM
1337's Avatar
1337
Well, i was thinking of buying a type r, but then one of my friends friends is selling his 99 ls body integ w/ jdm type r motor in it for 12,000...it is farely stock besids a AEM cai and toda spec b cam gears and it has only 30000 miles on the engine and 45000 on the chasi...does this sound like a good buy or should i jus save up sum more and buy a real usdm type-r...
Old Feb 29, 2004 | 03:00 PM
01ITR640's Avatar
01ITR640
That car sounds pretty cool. But nothing is better than the real R. Plus the real R's have 5 lugs.
Old Mar 1, 2004 | 05:24 AM
bbasso
Guest
Posts: n/a
The question is...
What do you want to do with the car?
Old Mar 1, 2004 | 03:00 PM
1337's Avatar
1337
well eventually i want to go to the expos and auto x, but i would buy sum good suspension either way
Old Mar 1, 2004 | 04:07 PM
bbasso
Guest
Posts: n/a
If your going to buy a good condition R, you won't have to change a thing for a while...
Just enjoy the car stock, many people including myself have and will continue to.
Old Mar 1, 2004 | 06:44 PM
Opie
Guest
Posts: n/a
I do, not by choice though :|
Old Mar 2, 2004 | 05:18 PM
kptrulee's Avatar
kptrulee
the ls seems like a good buy, stock the 99 ls is worth probably around 9-10k or so, and the motor itself he probably shelled out around $4000-5000 depending on the year and mileage on motor
but i would personally get the usdm R, the stock suspension on the R is great, u will definitely feel a difference in handling between the R and the LS
and 5 lug conversion is always a plus (wider wheel selection)
Old Mar 4, 2004 | 07:35 AM
revolution8k's Avatar
revolution8k
Buy the LS if it's cheaper than any R you can find. It'll be cheaper on purchase price and insurance rating.
Since you have a JDM ITR motor, all you'd need is a good suspension setup and you'll corner just like a real ITR, maybe slightly better.
Does he have the JDM ITR tranny in there as well, and if he doesn't...does it at least have an LSD?
Old Mar 4, 2004 | 04:25 PM
itr's Avatar
itr
ITR, you can't go wrong with it. Even leaving it stock you'll be satisfied.
Old Mar 8, 2004 | 09:49 PM
40calpal's Avatar
40calpal
Yeah i'd say get an R, or if u could find a 00' or 01' Canadian spec CW then thats the ultimate way to go.
I just think the R has subtle differences that make it better in everyway. Their limited availability, 5 lug as mentioned earlier, sideskirts, front lip and wing, (save u from buying a kit on the LS if u chose to) carbon fiber inlays, lighter weight and LSD but man i could go on forever.
Make sure u can afford the insurance on the R though, i'd assume the LS would be quite a bit cheaper
