lsd broken?????
Old Feb 17, 2004 | 10:06 PM
blue-streak's Avatar
blue-streak
Originally Posted by PSI_24
NO I KNOW ITS NOT MY TIRESS CAUSE THEYRE FAIRLY NEW.... CHECK MY TEAM AND I WENT CRUZIN ON SATURDAY AND MY CAR WAS RUNNIN DESENT.... WE STARTED MESSING AROUND LAKE SHORE DRIVE AND I RAN AGAINST A RSX-S..... WE BOTH LAUNCHED AND I TOOK HIM AFTER SECOND... THEN THE NEXT LIGHT WE WENT AT IT AGAIN, THAT WHEN I REALIZED THAT SOME WAS WRONG WITH MY CAR...... :cry: THE S TOOK ME BY ALOT AND MY CAR STARTED TO RUN LIKE SSHH****T :?:
holy caps lock
Old Feb 18, 2004 | 09:21 AM
Opie
Guest
Posts: n/a
Originally Posted by blue-streak
[quote:626af11c11="PSI_24"]NO I KNOW ITS NOT MY TIRESS CAUSE THEYRE FAIRLY NEW.... CHECK MY TEAM AND I WENT CRUZIN ON SATURDAY AND MY CAR WAS RUNNIN DESENT.... WE STARTED MESSING AROUND LAKE SHORE DRIVE AND I RAN AGAINST A RSX-S..... WE BOTH LAUNCHED AND I TOOK HIM AFTER SECOND... THEN THE NEXT LIGHT WE WENT AT IT AGAIN, THAT WHEN I REALIZED THAT SOME WAS WRONG WITH MY CAR...... :cry: THE S TOOK ME BY ALOT AND MY CAR STARTED TO RUN LIKE SSHH****T :?:
holy caps lock[/quote:626af11c11]
Holy lock Trey man :?
Old Feb 18, 2004 | 10:28 PM
otb2000itr's Avatar
otb2000itr
Originally Posted by FDTT
I dont beleave you can "brake" a LSD. Rather weare it out. Most LSD's are made up of clutch packs, or some sort of clutching mechanism. I beleave in a ITR it is sets of clutches. When the clutches wear your LSD will not work like it supose to.
ITR lsds are NOT clutch type as suggested. They are gear type. Clutch type are like KAAZ lsds...
Old Feb 18, 2004 | 10:30 PM
FDTT's Avatar
FDTT
Ok, wasent quite sure of that. So its like a Quafie then. With gears rahter than clutches. ok
Old Feb 19, 2004 | 12:35 PM
otb2000itr's Avatar
otb2000itr
You got it....
Old Feb 20, 2004 | 08:58 PM
AlvinOne7's Avatar
AlvinOne7
what do you guys think is a better lsd.... Quaife or KAaz
Old Feb 21, 2004 | 11:04 PM
98cwitr's Avatar
98cwitr
Where's the DC5R???
change your tranny oil...it helps a lot
