alignment
Old Feb 9, 2004 | 04:27 PM
Nick Amick's Avatar
Nick Amick
What do you do when you have 1 wheel that is way out of spec as far as camber and you run DS? My acura dealer does not sell crash bolts. I have found aftermarket ones. Does the factory service manual say to use them? If not I guess you would have to put it on a frame straightner.
Old Feb 9, 2004 | 06:45 PM
Trey
Guest
Posts: n/a
Nick, what did you do to the car man!?
Old Feb 10, 2004 | 02:58 AM
Nick Amick's Avatar
Nick Amick
It was nothing I did. Jerry and I put it on the rack for its first alignment since I've owned it and found the right rear wheel with -1.8 which would be ok if the other side was the same. I would like to get the car a little more neutral. Let me know if there is something I can do legally other than the rack. Thanks Nick
Old Feb 10, 2004 | 03:35 AM
Trey
Guest
Posts: n/a
Washers behind the top bolts on the on the rear upper control arm will add positive camber. I am not sure if this is legal or not but this is how you can do it.
