tire pressure ...
Old Feb 10, 2004 | 06:47 PM
mayhem's Avatar
mayhem
I run 205/50/15 toyo t1s on a stock 2000, daily street driven...
I was told by the first owner after trying several different combinations, 36lbs in front and 34lbs. in the rear was the best. But i was also told by a someone else,"that's to much , that would cause more wearing in the middle" . What do you guys think?
Old Feb 11, 2004 | 03:39 AM
Trey
Guest
Posts: n/a
The second person is probably right. I would think 32-34 psi on the street would be more appropriate. Try some pressures and watch for different wear.
Old Feb 11, 2004 | 06:14 AM
bbasso
Guest
Posts: n/a
I don't have those tires, but On MXs I have 38 F 37 R (cold temps)
I also use that for the track (hot temps)
Old Feb 11, 2004 | 07:03 AM
Tony
Guest
Posts: n/a
I have Yok ES100s as street tires, and I run 35 psi all the way around.
Old Feb 11, 2004 | 08:11 AM
nsxtasy
Guest
Posts: n/a
No one has mentioned Honda's recommendation, which is 35 psi front, 33 psi rear. That's what I use, and I find that it works just fine. I use the RE010 stock tire.
Those who mention 36F/34R or 34F/32R here - keep in mind that yours is only 1 psi different from Honda's recommendation, so it's pretty darn close...
Old Feb 22, 2004 | 03:40 PM
mayhem's Avatar
mayhem
Honda recomends 35/33 on 195/55/15 , instead of 205/50/15 which im running. But thanks for the replies.
Old Feb 22, 2004 | 05:13 PM
bbqman's Avatar
bbqman
Take into consideration that the manufacturer's recommendations usually tend to have the car understeer so that regualr drivers don't get into trouble.
A couple hints to help you set up your tire pressure.
Higher all around= better overall gasmileage ( good for roadtrips like Expo), harsher ride, longer warmup period and possible premature wear in the center.
Lower all around= more drag, better launch grip, smoother ride, worse gas mileage, unstable car at excessive speeds and uneven tire wear.
Higher Front/Lower rear= general understeer
Lower front/ higher rear= general oversteer ( car gets loose)
Keep in mind these settings with all things equal.
In my case, I use 30 all around on RA-1's and I put 35 in when I do a road trip.
For autocross, I generally run the rears quite a bit lower to increase grip as I like to use off throttle oversteer techniques.
In reality, there are no right or wrongs, just guidelines to help you choose a setup that fits your style.
BBQman
Old Feb 23, 2004 | 08:48 AM
BudMan
Guest
Posts: n/a
Carl -
That was a great overview! Nice job.
Now which setting was it that lets me run faster than you??? :shock: hehehe See you at the Expo!
Old Feb 23, 2004 | 06:22 PM
bbqman's Avatar
bbqman
That would be the setting in the bar before the next days activities. :roll:
Old Feb 24, 2004 | 04:35 AM
BudMan
Guest
Posts: n/a
ROTFLMAO :lol: That was a goooood answer...Yuengling is surely going to be found near by! 8)
