Greddy Type S adjustment
Old Feb 5, 2004 | 11:04 AM
F0rsfed's Avatar
F0rsfed
For some reason my bov dosen't seem to be working. Vaccum line and all is hooked up correctly but all I hear is the flutter which sounds like it is coming from my wastegate. Can someone help me out?
Old Feb 5, 2004 | 02:13 PM
ITR41's Avatar
ITR41
my neighbor has one on his GST I will find out how to do it later tonight
Old Feb 5, 2004 | 03:26 PM
Jan Niemi's Avatar
Jan Niemi
You should hook up a hand held vacuum pump (MityVac), and pull vacuum on it, about 17 to 20 inches should open the valve fully.
I keep mine adjusted all the way out, I get backspin if I tighten it much at all. BTW, make sure you don't have your vacuum hose hooked up to the bottom port, that's for boost-assist, it needs a boost-referenced line hooked up to it, but you can just leave it open, or plug the port.
Old Feb 6, 2004 | 09:36 AM
F0rsfed's Avatar
F0rsfed
YEAH i HAVE MINE HOOKED UP TO THE TOP PORT AND IT SEEMS TO STILL BE FLUTTERING.
Old Feb 6, 2004 | 01:14 PM
Jan Niemi's Avatar
Jan Niemi
Take your caps off bro, it makes it seem like you are yelling...
Anyways, I think you might still need to loosen the adjusting screw, I don't know if the fluttering you describe is backspin, or the blow off. Also where is your vacuum line hooked up on the other end?
Old Feb 6, 2004 | 04:52 PM
F0rsfed's Avatar
F0rsfed
sorry man I was at work when I posted that and we use caps for our program. Anyway I have the vaccum hooked up too the top port and it's running to my vaccum manifold which is getting the vaccum from the brake booster hoes off the manifold.
