obd1
Old Jan 27, 2004 | 10:31 PM
Y56ITR's Avatar
Y56ITR
on my 01 type R, how would i switch to OBD1? would i have to get da ECU from kenji? cause i know you cant just plug in the obd1 because of the immbolizer. and what kind ecu should i get and run it with?? to use full potential of my car.
Old Jan 28, 2004 | 04:42 AM
Erik B's Avatar
Erik B
depends on what your plainning on doing. All you need is a OBD2 to OBD1 harness and the ECU. You could use either a p72 (GSR ECU) or a p28 (any single cam ECU w/VTEC) The p28 is cheaper.
Old Feb 18, 2004 | 11:19 PM
itr's Avatar
itr
im just curious why would you go about using a P28 single cam with vtec for an itr?
Old Feb 21, 2004 | 10:29 PM
98cwitr's Avatar
98cwitr
Where's the DC5R???
I have ordered my ECU from Kenji with the harness. He is actually sending me a P06 and installing the VTEC function into the ECU :shock: As soon as it arrives i will post a review
Old Mar 9, 2004 | 06:36 PM
punkaddic's Avatar
punkaddic
Did you install your ecu obd1 ?? i would like to have your review since im thinking of doing the same thing. Thanks
Old Mar 10, 2004 | 06:48 AM
Erik B's Avatar
Erik B
very very very easy to do. It plugs right up.
To answer the question about why p28. You would only run this ECU if you was going to boost and use a Hondata. The all you need for a hondata is a OBD1 ecu with VTEC (for VTEC cars). People use the p28 because it's so much cheaper then the 72. Hope that clears things up.
