what size speakers?
Old Jan 25, 2004 | 06:16 PM
jdm cw type r's Avatar
jdm cw type r
what size speakers are in the front and rear of the type r? thanks
Old Jan 25, 2004 | 06:41 PM
98cwitr's Avatar
98cwitr
Where's the DC5R???
6.5"
Old Jan 25, 2004 | 06:44 PM
01ITR640's Avatar
01ITR640
6.5", although I've discovered in the past that not all speakers fit in the integra. Their is not alot of room for a bigger magnet. Also their is very little wire in the rear to work with so it makes it difficult to replace.
Old Jan 25, 2004 | 06:58 PM
Stock97ITR#50's Avatar
Stock97ITR#50
If depth is an issue as it will be for me soon, make mounting plates from plywood to bring the speaker basket out from the door a little so you can still roll the windows down. :wink:
Old Jan 25, 2004 | 09:50 PM
LT6916
Guest
Posts: n/a
the front wire harness also is very short, leaving little to work with.
Old Jan 25, 2004 | 10:42 PM
B2FiNiTY's Avatar
B2FiNiTY
I would recommend just cutting the harness and using some nice connectors to connect everything. That way you get a lot more room to play with.
Old Jan 26, 2004 | 03:35 AM
Trey
Guest
Posts: n/a
I've found it easiest to use 6" speakers. most aftermarket 6" fit well. I use JL audio and they fit tine with not modification except cutting the stock plastic basket they sit in.
Trey
Old Jan 26, 2004 | 10:01 AM
bbasso
Guest
Posts: n/a
I used my dremel to cut the plastic basket to fit my 6.5 speakers in, other then that no other mod was nessary. (for the front)
Old Jan 26, 2004 | 10:53 AM
Trey
Guest
Posts: n/a
I used a dremel as well but the JL 6's seem to be a bit oversized. 6.5 woudl never have fit.
Old Jan 26, 2004 | 11:43 AM
bbasso
Guest
Posts: n/a
I went with the Pioneer premiers...
