"Brake" Cluster light problem.
I've only had my R for about 3 months, I bought it off a a 49 year old guy so I don't think it was beat down. Anyway..... When I start my car in the coolness of the morning (we're talking Florida coolness, so it's maybe 85 degress or so) the brake light on my cluster stays lit even when I release my emergency brake. Even if I release it before starting the car or what not it stays lit. This happens until the car warms up or after about 5 minutes of driving, then I can be cruising at 40 or so and tap the brakes and the light goes off, but as soon as I hit the throttle again, the light comes back on, and once again I could tap the brakes and have it go off. This will contintue until I've been driving for maybe 10 minutes when I'll tap the brakes, and the light will go off for good. (Almost like heat has something to do with it.) Now if I start my car at like 1:00pm, it's fine, the brake light goes off like normal and never comes back on, then as it gets cooler into the evening and night, the same problem happens. I haven't taken it to a shop because I don't want to hear the bs story of me needing new rotors and all that other garbage. So, anybody have any ideas?? Maybe a sticking cable or something? Sorry for the long post.
Guest
Posts: n/a
Check the brake fluid level. It's probably just low. If that's not the problem, replace the resovior cap. The sensor in it goes bad. Most likely you just need to add some fluid though.
And it's been nice in st pete lately, not 85 degrees in the morning :P
Guest
Posts: n/a
Originally Posted by OPIE112
Yup, No brake fluid in my CRX will any brake fluid do the job? is there any bleeding necessary if im just adding fluid?
Guest
Posts: n/a
Originally Posted by Dave-ROR
[quote:cee0f60ee7="OPIE112"]Yup, No brake fluid in my CRX will any brake fluid do the job? is there any bleeding necessary if im just adding fluid?
Thanx for the response Dave, but the resevoir was just low, I just took the cap off and wiped it off, and through some brake fluid in. No mor light, now I have to check my R!
