FINALLY broke in the 14's
Originally Posted by Trey
1.8 to 1.9 60' on street tires isn't gonna happen. Slicks it will.
2.2-2.3 isn't a bad 60'. You might be short on midrange power. Considered a VAFC or Hondata?
As far as the mid/high 13's comment, I wouldn't get frustrated if you can't hit those times....its very rare in a ITR you could say... Other than Trey on this board, I've never EVER seen a true ITR run faster than 14.4 so I think you're off to a good start... I personally run 13.8's on street tires (Falken Azinis-17psi) but I have a JDM R in a Civic Si Coupe. Keep trying, it'll come... I have several dozen's of video footage of stock R's running 15's all day long so... Congrats getting into the 14's... Any real drag racer that has been doing this sport for a while knows that just that simple 10th of a second feels like an impossibility sometimes.
Originally Posted by Jan Niemi
I've pulled numerous 1.8s and 1.9s on street tires. You do realize that Drag Radials are street tires (impractical but true)
Where's the DC5R???
launch at around 5,500-6,000 slip the clutch for a good whole second and DO NOT put the throttle to the floor, keep it right where it is until you gain traction and then floor it, you should be at around 6,000 rpms (in vtec) when you put it to the floor. that should be good for 2.1 60fts and drop you into the mid 14s...you are a lucky man that your tach isnt off, i shift at (tach reading) 9,000. ops:
