SAFC settings
What do you guys say my settings should be around, I dont have money to get it on a dyno with a wideband. I just want it to run pretty good for now, mean while I save money for hondata and tuning. I am running stock injectors and stock fuel pump. Pressure is boosted up but I need a gauge to know exactly where its at. Thanx.
without knowing your setup, it's impossible to help you out.
Rememer this though
A: the ass-dyno is not calibrated and lies
B: make small changes at a time the stock R fuel map is rich in certain areas, benefits can be had by removing fuel in these areas, but again without knowing your mods.....
Rememer this though
Turbonetics t3t4 turbo
SFP manifold and downpipe
b&m fpr
I am only boosting 4 psi right now but want to boost around 7-8. I dont have any idea what my air fuel is at right now. I just want to drive it without worrying about fuel failure. What should I set my fpr at??
b&m fpr
Turbonetics t3t4 turbo and wastegate
HKS bov
apex safc
spearco intercooler
I am only boosting 4 psi with stock settings on the SAFC, but want to boost up to 7-8. I do have some RC 550 injectors to go in it but dont have a fuel pump yet. I was just wondering what u guys settings are at with stock injectors.
HKS bov
apex safc
spearco intercooler
the afc will NOT trim enough fuel to run 550's. you are probably detonating now honestly. your FPR is 1:1 so you are way short on fuel. it is not the fuel pump that is holding you back most it is the injectors and the fact you don't even have a FMU. where is your timing set at? if I were you I would get a 12:1 fmu and missing link and drive it like that. don't even mess with settings till you get to a dyno. if you are runnin a missing link now you are DEFINITLY detonating. the missing link tricks the ECU into thinking you are at 0 vaccum when you are at full boost so the ecu does give you enough fuel. so this is what you need:
12:1 fmu-100 bucks used
missing link-20 buck used
until you have those 2 things I wouldn't drive the car at all....at least get a EGT gauge and if you are over 800 degrees C I wouldn't drive it.
