will my motor take it????
Old Sep 27, 2003 | 08:36 AM
vteckiller's Avatar
vteckiller
i will be ordering my drag gen 3 turbo kit within the next month. I was wondering if the stock block will handle it. I will run 5-7 psi. As of right know i will be using v-afc for engine managment . is there anything else you would recomend. I will also be purchasing aem true time gears to adjust timing. Also apprx how much will it cost to have installed. thanx
Old Sep 28, 2003 | 10:13 AM
Jan Niemi's Avatar
Jan Niemi
The stock motor will take that level of boost as long as the fuel and timing is right.
Old Sep 28, 2003 | 07:24 PM
ITR41's Avatar
ITR41
I would go with skunk2 gears cause AEM's have a tendency to slip. also for added safety get the inline pro head gasket and block gaurd. www.inlinepro.com
also I would recommend a rev hard kit over drag. they are just better all round kits.
I run 15psi daily with the head gasket and block gaurd from inline pro. I have DSM injectors and vafc with a 12:1 FMU and missing link. the system works fine but expect MPG to suffer....good luck
ITR41's Avatar
ITR41
Old Sep 29, 2003 | 01:16 PM
Erik B's Avatar
Erik B
Tuning Tuning Tuning is the key with a boosted b18c5. Good luck.
