tire rubbing help !!!!!
Old Sep 11, 2003 | 05:45 PM
b18c1's Avatar
b18c1
hey guys.
my tires r rubbing against the frame when i go into full steering lock. i'm running 17x7 rim with 205/40/17 i even try to put my stock wheels back in , but still rubbing any one got same experience.or any suggestion???
Old Sep 12, 2003 | 06:11 AM
e r i c s 9 9 s i's Avatar
e r i c s 9 9 s i
usually they're gonna rub when you crank the wheel all the way and try to pull a U-Turn. How low are you? Try slowing down a little bit when you make the hard turn..
Old Sep 12, 2003 | 10:37 AM
b18c1's Avatar
b18c1
i still can stick 1 finger between the tire and the fender.the rubbing just killing my tires, is it something to do with offset??
Old Sep 12, 2003 | 11:03 AM
Dave-ROR
Guest
Posts: n/a
offset will do it. When my car was that low it rubbed with stock wheels too though so the ride height is also a contributing factor.
Old Oct 11, 2003 | 04:02 PM
VtecWhore's Avatar
VtecWhore
yeah i gots that same problem. i thinks its the offset.
Old Oct 13, 2003 | 03:51 AM
Trey
Guest
Posts: n/a
Height, Tire Width, Offset can all affect it. That said at full lock my stock wheels with 205/50/15 will rub. Best suggestion is not to go to full lock.
