Brakes
Guest
Posts: n/a
Originally Posted by The Question
hey can anyone tell me the top best brakes i should get for my 16" jdm 98 wheels for itr? brembo, mugen, spoon? brembo is too big for 16"... i need to know the real good brakes for 16" wheels
no not really but yeah... its been abused from racing, and i dont get that good of pedal response anymore... besides just basically want to upgrade to a big brake caliper setup for my racing needs
Guest
Posts: n/a
stock brake calipers with solid rotors and good pads/fluid = plenty of brake for practically any ITR race car. Yes, there are exceptions where larger rotors are needed for their thermal mass. Larger calipers can be useful for exerting more force (although calipers like spoon's don't) and for more even pad wear and slightly better modulation. Without knowing what racing you are involved in it'll be hard for anyone to make correct suggestions that fit your needs.
yeah tru i only need the big brake uprgrade for exerting more force n heat better than stock... i know stock is good enough for autocross but for me i just want to get the best besides i most likely will not get a big brake caliper because most of the great kits can be used with 17" or higher wheels n i want to keep the jdm 98 spec itr wheels on... just wanted to get some suggestions
Guest
Posts: n/a
You don't want the calipers to hold heat, that's the job of the rotors which are then cooled through their venting. Unless you go offroading, stick with solid blanks, otherwise use slotted. Do not use cross drilled unless you want it for show (which it seems that you don't care too much about showing your brakes off). Spoon calipers will give you better modulation but have the same piston contact area as the stock calipers. Not worth the money IMO.
Guest
Posts: n/a
Dave is 100% on point. The stock brakjes are more than yo using and upgrading will moo likely doy little for the money it will cost you.
Sounds like you need to do regular maintenance on your current setup to improve performance and pedal feel. Put on a fresh set of pads and bleed the brakes.
Trey
Trey
