Vtec lag
Old Aug 8, 2003 | 08:37 PM
98 Supercharged R's Avatar
98 Supercharged R
This might be a retarded reply but if your running synthetic oil it could be the problem,I talked to another guy with a type r and he said synthetic doesn't work good on vtec engines cause of the vtec silinoids(yeah i can't spell)and how synthetic is too sticky or some crap like that
Old Aug 11, 2003 | 07:22 PM
Jan Niemi's Avatar
Jan Niemi
If you change the VTEC crossover point with the VAFC, you absolutely must adjust fueling as well. Start with -5% HI, +5% low, once you get this right you will definitely notice a difference, I have VTEC set at 4800, and on boost she just takes off as soon as the transition occurs. It's all about the fueling. If you need more help with specifically adjusting the VAFC let me know, make small changes, if you don't have access to a dyno it' s not worth the engine damage.
