Rebuilt Motor Help!!!!!!!!!!!!!!
Old May 31, 2003 | 10:53 AM
JDMITR98's Avatar
JDMITR98
I love my ITR
I just got my motor rebuilt and at first it seemed like it had alot of torque and my throdle responce was alot better then before, but now it has lost it all- no torque anymore, We can't fugure out what has happend. The battery tested out OK. I am worried because the machine shop that rebuilt it said that since it was running to rich (both of my o2 sensors are bad) that it may be loseing compression from the rings going bad already(it only has 725 miles on the rebulit motor) HELP please!!!!!!!!!!!!!!
spec's on motor- SRP oversized 11.4-1 compression pistons, Eagle H-beam rods, and Mugen headgasket.
Old May 31, 2003 | 12:14 PM
Reid's Avatar
Reid
Do a compression test and also a leakdown test.
If you are running extremely rich, fuel may be washing oil off the cylinder walls.
Old Jun 4, 2003 | 12:16 PM
JDMITR98's Avatar
JDMITR98
I love my ITR
The car is running rich but not that bad- I found out it has blow-by so all I know about that is it could be the rings?? Anyone else have any suggesitions?Please???????????????
Old Jun 4, 2003 | 12:18 PM
Dave-ROR
Guest
Posts: n/a
Old Jun 5, 2003 | 10:18 AM
Zodiac R279's Avatar
Zodiac R279
Originally Posted by dawhiteboy
[quote:e4820f3313="JDMITR98"]Anyone else have any suggesitions?Please???????????????
[/quote:e4820f3313]
Is your ECU throwing any codes? I know sometimes when there are problems with your sensors the ECU will run in Safe mode so as not to allow you to cause damage to the engine. this will inhibit the performance of the car as well. Try resetting the ECU (disconnect it from the battery for a few minutes and see if that makes a difference. However if there is a problem it may return to safe mode after a while.
Old Jun 5, 2003 | 01:49 PM
Reid's Avatar
Reid
The problem is her rings are going.
You are going to have to rebuild again.
Old Jun 5, 2003 | 02:26 PM
JDMITR98's Avatar
JDMITR98
I love my ITR
Originally Posted by Reid
[quote:dde0639ccf="Zodiac R279"]Is your ECU throwing any codes? I know sometimes when there are problems with your sensors the ECU will run in Safe mode so as not to allow you to cause damage to the engine. this will inhibit the performance of the car as well. Try resetting the ECU (disconnect it from the battery for a few minutes and see if that makes a difference. However if there is a problem it may return to safe mode after a while.
The problem is his rings are going.
You are going to have to rebuild again.[/quote:dde0639ccf]
"Her" rings-sorry yes I am a girl. I am getting a compression test and leakdown done tomorrow I will let you know the numbers
And do you really think I am going to have to rebuild again after only 700 miles?? I drove it like a baby. That is a bunch of crap- this Type R will be for sale if that is true.
Old Jun 5, 2003 | 03:15 PM
Reid's Avatar
Reid
Why did you rebuild it in the first place?
What procedure did you use to break in the motor?
Old Jun 5, 2003 | 09:02 PM
Zodiac R279
Not sure why the rings would go bad so soon and you are still breaking in the engine. But if that is the case you will have to replace them which means removing the head and the pulling the pistons. But my guess is that the person who installed them must have done something wrong. OR the operator didn't break in the engine properly OR the Rings were Bad or defective
Old Jun 6, 2003 | 12:53 PM
JDMITR98's Avatar
JDMITR98
I love my ITR
Hey now it was not the person who broke it in. When I broke it in I only got on it once after 500 miles and an oil change- then it had oil leaking problems from the oil pan, valve cover, and the PVC valve- all which were new gaskets.
From then on it has just been downhill :cry:
