Post Your Tuning Tips
What are your tuning stratagies? Where do you start? What do you adjust first? I know you begin with everything set at factory spec.
Post up your tuned numbers and whats done to your motor? What are your settings set at (Fuel Pressure, Cam Gear Settings, Distributor Timings, VTEC engaugement, etc..)? What tuning devices do you personally use (V-AFC, Hondata, ECU swap, etc..)?
I think the best tuning for me is done at the dragstrip, when I MPH high, I know I'm making power. Stock distributor timing (static), the ignition timing is at the will of the vafc (don't like it but all I can afford right now)
I like to have real-world results for my tuning efforts, dyno numbers don't mean that you have a fast car. Refer to USCC ITR making 380whp, running 13s.
Guest
Posts: n/a
Hondata actually suggests set the AFR then do Timing.
Then cam gears.
I really suggest checking these out.
http://www.itrca.com/FAQ/tuning/
Then cam gears.
