What do i need to get for my 45,000 mile checkup?
Old Apr 8, 2003 | 06:01 PM
01ITR#158's Avatar
01ITR#158
I just about have enough $ for my 45000 mile maitenance check. What are the things i should get done? Tires rotate, fluch fluids, adjust valves (specs 7 on intake 8 on exhaust, or other way around?). What else should i look to get done. Any help would be appreciated!!!!
Old Apr 9, 2003 | 07:51 AM
Aj's Avatar
Aj
Flutch fluid huh? JK, you should bleed your clutch and brakes, just make sure you use a DOT4 brake fluid, this way you dont boil it, assuming you drive as hard as I do. You'll definitely want to adjust the valves, and yes it is 7 - intake and 8 - exhaust. You also want to add some power steering fluid, change your tranny oil (10w30/MTF), change your engine oil, tighten your ebrake cable, and other than that, I can't think of anything else. If you do all that, you pretty much covered the bases.
Later,
Aj
Old Apr 9, 2003 | 08:27 AM
Type R 98's Avatar
Type R 98
how can i find the way to figure out how to tighten my E brake, mines loose as a mofo...
Old Apr 9, 2003 | 11:37 AM
Aj's Avatar
Aj
Take off the center console, it's only four screws(side on console) and two bolts (under E-brake under cover) You'll see the adjustment. just dont make it too tight, otherwise it'll make your rear brakes rub while your driving...
Later,
Aj
Old Apr 17, 2003 | 03:28 PM
pUrExTc's Avatar
pUrExTc
殺生丸
what do u mean u just have enough money for ur 45000 mi. check up? how much izzit anyway?
Old Apr 17, 2003 | 07:27 PM
Airbag's Avatar
Airbag
I just did my 30,000 mile check up and it turned to be more expensive then I thought. The dealer changed transmission fluid, brake fluid, engine coolent, rotate tires, inspect tie rod ends , steering gearbox, inspect all lights (like I can't), lubricate all hinges, inpected all hoses, cooling system, exhaust system, inpected fuel lines and connections, they also inpected valve clearance, adjusted valves and checked idle speed. They inspected that and more little stuff for a whopping 450.00. pretty expensive.
Airbag's Avatar
Airbag
Old Apr 18, 2003 | 12:05 AM
Aj's Avatar
Aj
If you actually read the stuff that hey do, there's not a lot involved, and none if it's stuff that you couldn't do in your drive way. The only thing I would suggest you have acura do, is the valve adjustment. It's one of those things that if you don't know what you're doing, you probably shoudn't screw with. Other than that, save yourself the didge and do the rest....
Later,
Aj
