Clutch help!
Old Apr 7, 2003 | 09:46 AM
Stock97ITR#50's Avatar
Stock97ITR#50
I just went to lunch and the R is acting strange. The gear engagement is very difficult (at the shifter) and when I release the clutch the engagement is very rough and abrupt. BTW, the clutch was squeking slightly upon depression. Could it be the spring? I couldn't see any leaks from either cylinder. The car has only 31K.
Old Apr 7, 2003 | 01:28 PM
bbasso
Guest
Posts: n/a
Sounds like you need a clutch, good luck.
BTW I went with the ACT xtss and its very nice even on the street- a hair or two more then the stock (pedal pressure).
Old Apr 8, 2003 | 11:41 AM
Aj's Avatar
Aj
Yeah, it does, and I'd do it sooner rather than later, so you don't cause some problems in your tranny....
Later,
Aj
