hi flow cat question
Old Feb 22, 2003 | 09:43 PM
blee's Avatar
blee
i was looking at random technology's hi flow cat for the itr, but they only list a one for the gsr. are they the same? thanks ahead of time if anyone answers this.
Old Feb 23, 2003 | 10:46 AM
Champ R's Avatar
Champ R
Carsound makes a few different sizes for hondas, from 2" to 3" i think. Most ITR guys run 2.5" carsounds or slightly modified ones from SMSP.
Old Feb 23, 2003 | 01:15 PM
blee's Avatar
blee
is the 2.5 a direct bolt or you need to modify it a bit? also where can i get a carsound cat. i'm in so cal. thanks for the info.
Old Feb 23, 2003 | 02:11 PM
kabob's Avatar
kabob
A 2.5" cat only bolts directly onto a header with a 2.5" collector (JDM-spec header) and a 2.5" catback. The ITR uses 2" piping all around but I have no clue what a GSR uses.
Old Feb 23, 2003 | 02:44 PM
Type R 98's Avatar
Type R 98
isn't usdm ITR 2¼ piping front to back? and can you get a car sound Cat that hooks to JDM header AND hooks to a USDM Catback
Old Feb 23, 2003 | 04:29 PM
kabob's Avatar
kabob
Yeah, but you'd have to order one from Carsound with different diameter inlet and outlet.
Actually, you're right almost. The header is 2" and the catback is 2 1/4"... one of you guys correct me if I'm wrong
Old Feb 25, 2003 | 03:56 AM
Trey
Guest
Posts: n/a
just check with Mike at www.ipsracing.com or Dave at smsproduct@earthlink.com
They can both make custom length cats.
Old Mar 5, 2003 | 10:52 AM
TypeR00_0371's Avatar
TypeR00_0371
GSR cat is 5" shorter than the ITR, LS, GS, & RS,
Trust me, Whatever you do DO NOT buy a Comptech cat.
First they'll send you a GSR Cat, then they'll double charge your credit card to send you the RIGHT one, and then about 5000 mi. after you put it on, the screens crystalize and cause restriction. Too Bad your in Cali.
I'd sell you my "GUTTED" Comptech, but it wont pass the sniffer test, or whatever it is you call it...
lat'
Scott Boller
Old Mar 5, 2003 | 11:02 AM
Trey
Guest
Posts: n/a
lat'
Scott Boller
GSR is only different from 1994-1999. 2000 and 2001 is the SAME length
Old Mar 5, 2003 | 11:31 AM
TypeR00_0371
really? hmmm... *Standing Corrected*
