supercharger
Old Feb 8, 2003 | 06:57 AM
2001 integra type r's Avatar
2001 integra type r
i was wondering i own a 2001 integra type r and i was thinking of putting a jr supercharger and i was wondering who much hp and torque it will have if i put it on and i was also wondering about getting a zex dry nitrous 55hp and i was wondering if both of them would be good.
i am a beginner so answer where i understand.
Old Feb 8, 2003 | 08:53 PM
ITR41's Avatar
ITR41
rule of thumb is never to run a dry system. I would use a wet system from NX or NOS. the JR charger is OK but won't give you much boost in performance till you run about 8 psi. you need to lower compression either with a head gasket from Inline pro or forged pistons. it is a decent set up but not the best for the long run....ohh I would avoid runnin a nitrous system and a blower at the same time. just get JR water injection if you get the blower
Old Feb 9, 2003 | 11:13 AM
2001 integra type r
thanks itr i just would think that you have a dry nitrous b/c it wouldnt tear up as much as a wet?
thanks any way
Old Feb 9, 2003 | 01:40 PM
Jan Niemi's Avatar
Jan Niemi
Dude,
don't waste your money on a supercharger. Go turbo, my friend . Intercooled boost is better than non-intercooled boost. At least don't use the JR set up, use a procharger or paxton or vortech, something you can intercool. This is vital with high compression cars such as ours.
Old Feb 9, 2003 | 05:19 PM
ITR41's Avatar
ITR41
centifugal SC's make a lot of power but are just dyno queens. they are usless in street driving.
Old Feb 9, 2003 | 07:09 PM
Jan Niemi's Avatar
Jan Niemi
I'll have to agree, whatever supercharger you use. They all make power as a function of rpm, therefore very linear and make peak power at peak rpm, where it's virtually untouchable. That's why I say go turbo!! I'ts just that if you are going to sc the car, make sure it's safe boost, hence the intercooling.
Old Feb 10, 2003 | 12:22 PM
fredtoast's Avatar
fredtoast
Some people have gotten good results from the sc+nitrous setups. If you are interested in going that route then search the "forced induction integra" forum at hostboard.com. You'll find a lot of info there.
I have a jrsc on my ITR, and I love it. However, I just wanted a reliable boost for a daily driver. At 8 psi I didn't have to modify anything else except the fuel pump. However, if you are looking to boost over 10 psi I would suggest you go turbo. The sc delivers the power instantly all the way across the powerband, but for big top-end power the turbo is the way to go.
Good luck with whatever you decide to do. PLease let us know how it comes out.
Old Feb 10, 2003 | 12:26 PM
fredtoast's Avatar
fredtoast
BTW you can check out jacksonracing.com for info on hp gains. Their results are slightly overstated. I'd say about 10 to 15 hp more than most people experience. Still it is a big gain all the way across the band.
Old Feb 13, 2003 | 03:32 PM
Spunkster's Avatar
Spunkster
I'm making 245hp and about 171tq at 9 psi with stock internals.
The key is tuning.
I'm using a hondata s200 with RC 440cc injectors.
