Look at my head....
Three things for sure
1) Green paint where the cam sits
2)pr3-4 stamped on the side of the exhaust
3)30 stamped where the other cam sits
This is besides the porting done near the valve seats and the flash removal.
I think this was answered peviously in another thread..........
Sounds close enough, I'm not exactly sure what number they were stamping back in 98', but I do know for sure that anything with the Prefix of PR3 is an either B16 or B18C5 head casting, the only other car that uses the same head code is the Si and the Civic type-R, easy way to know it's not a civic, is check the side of the block and make sure it's not stamped ethier B16A, B16A2, or B16B, otherwise, it's more than likely a type-R, unless someone went though a lot of trouble to fool you.
If you're really concerned, take off the valve cover, and look to see if the valve springs are painted yellow and blue alternating between hot and cold sides.
Any way, Later,
Aj
Any way, Later,
Aj
