Check Engine Light
Old May 1, 2003 | 07:56 PM
rosenjoseph's Avatar
rosenjoseph
Thanks for all of the help. My first problem was caused by bad gas. After burning it off, everything was ok. I have not tinkered w/ my bouncing idle yet. I did find the "Check Engine Light" reset button that Aj spoke about. It was under the driver's side dash. Just follow the right side of your steering column down your dash until you find the button. It was a light blue square on my '01 ITR. Hold it in while having the key turned to the accessory mode and the light should go out on its own. Thanks again.
Old Jun 8, 2003 | 06:41 AM
mydc2200's Avatar
mydc2200
i got the same problem as you when i accelerate to 5+, not very often
