Engine Oil
Old Nov 20, 2002 | 02:49 AM
ITR1140's Avatar
ITR1140
Hi Guys, I am going to change the engine oil in my R this weekend, just wanted to know what engine oil u guys recommend? Or are using?
I am currently using Motul, but its too damn expensive....
Thanks in advance
Old Nov 20, 2002 | 03:48 AM
00ITR#756's Avatar
00ITR#756
I switched to mobil 1, but I see no advantage. I am switching back to Quaker State.
Old Nov 20, 2002 | 03:37 PM
bbasso
Guest
Posts: n/a
Mobile 1 5/30 since day one. and I have used it on many of my past cars also.
Old Nov 20, 2002 | 03:46 PM
ITR1140's Avatar
ITR1140
Is it the Mobil1 Supersyn(sp?) ?
Old Nov 20, 2002 | 06:03 PM
kabob's Avatar
kabob
Mobil 1 is Mobil 1. Just look for the synthetic oil and the 5w-30 weight has red lettering on the label.
Old Nov 20, 2002 | 07:27 PM
bbasso
Guest
Posts: n/a
like he said Mobile 1 is M1, by the way 5/30 is the only thing you should use.
And I use the M1 oil filter too
Old Nov 20, 2002 | 11:19 PM
B2FiNiTY's Avatar
B2FiNiTY
Cheaper: Castrol GTX 10w30
Expensive: Mobil 1 10w30
Old Nov 21, 2002 | 04:22 AM
Trey
Guest
Posts: n/a
I used Mobil1 in all my integras and always burned a quart between oil changes. I am currently running amsoil since the M1 switch to fauz synthetic. I also run 5W30
Old Nov 21, 2002 | 04:28 AM
bbqman's Avatar
bbqman
I started with Castrol Syntec 5/50 and later switched to Mobil 1 15/40.
I'm back to Castrol becuase it seems to consume about 1/2 liter less per oil change.
Both are excellent oils and my driving style is constant with both.
Old Nov 22, 2002 | 11:59 AM
quikRthanU's Avatar
quikRthanU
ive been using castrol gtx and a bosch oil filter
