Question about ITR idle
Old Nov 16, 2002 | 07:35 AM
FBP ITR#00-0202's Avatar
FBP ITR#00-0202
If I have been driving and I come to a red light, or some place where I have to stop.. The car idles up at like 1500rpm for about 10-15 seconds.. after that it drops down to normal.. What could be causing that? It's pretty damn annoying at times.
Old Nov 16, 2002 | 05:49 PM
bbasso
Guest
Posts: n/a
Normal, all of the ITRs do it, including mine.
Old Nov 16, 2002 | 09:08 PM
B2FiNiTY's Avatar
B2FiNiTY
Completely normal.
Old Nov 17, 2002 | 01:09 PM
Aj's Avatar
Aj
Actually thats not quite tru, and it's not normal.
I'm not sure why yours does it, but it's ussualy if you've messed with either your TPS, or you IAC.
I actually switched to OBD1, which has caused a whole world of problems with my idle, but before I switched recently, when I was using my stock ECU, or when I switch back, nothing like that happens, if I drop the clutch it always goes back to about 850 rpms regardless of how I was driving. Out of all the ITRs I've driven at the shop. I've never noticed that any of them do it.......Not saying that none of them have, I just figure that would be one of those more noticable things, as you said, it would be pretty annoying.
If it's still under warranty, take it back to the dealer, and they'll hook it up to the computer, and make sure all the readouts, are with in the specified parameters.
Good luck......
Old Nov 18, 2002 | 03:34 AM
Trey
Guest
Posts: n/a
Could be worse mine fluctuates idle after it has been run hard. then stabilizes.
Old Nov 18, 2002 | 11:05 AM
bbasso
Guest
Posts: n/a
OH! The five Rs I have been in all do the idle thing then rest at 850-900.
go figure some do some don't.
Old Nov 18, 2002 | 04:28 PM
pUrExTc's Avatar
pUrExTc
殺生丸
My ITR idles around 1500 RPM when started on a cold engine, but after it's all warmed up, it likes to sit around 900 RPM. However, if you sit there and turn your steering wheel this way and that, it kind drops a bit (same as if you turn on your A/C). But I've never heard of stopping at a stop light, and having it raise up, and then drop.
Old Nov 18, 2002 | 08:05 PM
itr's Avatar
itr
happens to me also. i think it idles higher when the fan turns on.
Old Nov 19, 2002 | 05:39 AM
00ITR#756's Avatar
00ITR#756
I believe the reason for this is emissions related. The idle is kept high while leaning out the fuel mixture to lower emission. When the throttle blade slam shut, the fuel mxture is still very rich. This is checked during a smog test. Here in Massachusetts, the cars are accelerated on a dyno at a certain rate to 30 MPH. At 30 MPH, the gas is released, thus closing the throttle blades and causing the emissions to go up. If you don't let the car idle down, you won't get that spike in emissions. This is the way car manufacturers get around smog tests. Car pollute worst at idle.
Old Nov 19, 2002 | 07:54 AM
pUrExTc's Avatar
pUrExTc
殺生丸
ok, this isn't like some life or death for my car question, but i am curious. start your car (cold motor, might work warm, but never tried it). Sit there and watch your RPM on your tach. While still on a cold motor, turn the steering wheel this way and that. as you turn it, did you notice your rpm drop, and hear the valves reset? when you stopped turning it, did your rpm go back to normal warming range? why does it do this? (leave your E-Brake up, so you're not moving, of course).
