B20 in a Type R?
Old Nov 11, 2002 | 03:12 PM
pUrExTc's Avatar
pUrExTc
殺生丸
I met this girl, (my Type-R caught her eye, because her ex had a 2000 Type R). She asked what I had done and I explained just AEM CAI, and planning to go all motor. She continued to say that turbo is the way to go in a Type R. If you've read my posts you know I don't agree with Turbo in a Type R. She said her ex had a B20 (CRV motor) in his Type R with turbo running 7 lbs of boost. CRV motor in a Type R???????
Old Nov 11, 2002 | 08:10 PM
TegR#0989's Avatar
TegR#0989
Damn that sounds like a waste? Hope he at least kept the C5.
Old Nov 11, 2002 | 11:17 PM
pUrExTc's Avatar
pUrExTc
殺生丸
I don't understand it at all myself...if anyone does...please explain!
Old Nov 12, 2002 | 05:50 AM
dohcsideSi's Avatar
dohcsideSi
i'm sure it was a b20vtec she was talking about not just a str8 b20....i have a fully built b20vtec :twisted: going into my R this winter.
Old Nov 12, 2002 | 12:27 PM
pUrExTc's Avatar
pUrExTc
殺生丸
like i said though...y? the B18C5 is great already! besides, all motor in a type r...i think most on here would agree?
Old Nov 12, 2002 | 03:57 PM
paul98itr's Avatar
paul98itr
Definatly would agree. I would go out and get a gsr or ls or something and put a b20b if i wanted to. But then i would end up putting a b18c5 in the car so never mind. :lol:
Old Nov 12, 2002 | 05:22 PM
TegR#0989's Avatar
TegR#0989
Right Right - True True!
Old Nov 12, 2002 | 09:22 PM
pUrExTc's Avatar
pUrExTc
殺生丸
perhaps dohcsidesi can shed some light on this?
Old Nov 12, 2002 | 09:45 PM
Aj's Avatar
Aj
People use the B20 bottom end the same way people use LS bottom ends, because it will bolt up to any B-series head with a slightly higher deck height, this way you now have a 2 liter without having to re-sleeve your block, or bore it out any. It gives you a world more torque.
The only problem with ruunning a B20/PR3-4block/head combo, is that you have to run an extra oil line for vtec, buy or use your old vtec water and oil pumps, and then to get the correct rod/stroke ratio, you need a B17 crank, which is out of an older GS-R, which aren't exactly easy to come by, and very expensive from the factory.
As far as the B20 or CRVtec as it's more commonly called, is a wasted step on a turbo car, just boost another pound or two on a large enough turbo, and you accomplish the exact same thing.
The CRVtec if done correctly can be a lethal combo, the only issue once again, is that it frequently, unless you have the parts sitting around, quikly becomes very expensive, and ussualy not worth the effort.
Though I have to agree, all motor is the way to go, but as far as all those "Go fast crack adicts" out there, some need more speed then others.
In any case, to answer your questions very simply, you don't put the whole B20 in, just the block, although I do have a friend who stuck the whole B20 in a EG hatch that halls ass.
Any way, hoped that answered all your questions....
Later!
Old Nov 19, 2002 | 12:20 PM
dohcsideSi's Avatar
dohcsideSi
i went with the b20 vtec because i already had the motor and i bought my itr w/ no motor soooo...if i had a c5 to begin w/ i would sleeve it to a 2.0
