compression questions.
Old Nov 6, 2002 | 10:20 AM
alex b's Avatar
alex b
here in las vegas, most of the pumps carry 91 octane. the chevron i go to has 92. so what is the highest compression i could take my motor to with out detonation/knocking on 91/92 octane?
thanks.
Old Nov 6, 2002 | 11:04 AM
Trey
Guest
Posts: n/a
I think a safe rule of thumb is 12:1 You might get away with more but with weather changes that margin will vary.
Old Nov 6, 2002 | 11:40 AM
alex b's Avatar
alex b
trey, man thanks so much. you're a well of knowledge. 8)
Old Nov 8, 2002 | 12:24 PM
Aj's Avatar
Aj
The guys that I work with who came from Cali, and all the guys out at Jun that I've been fortunate enough to pick their brains, all said that they're running right about 12.3:1 compression.
They all told me, that if you're willing to screw with your timing when it gets closer to summer, then you could get away with like 12.5:1, just be careful about pinging.
I run 12.8:1 on 93 octane, but I also run my timing at 14 degrees, which is 2 degrees negative, though it still runs just fine, and fast as hell. Doesn't ping at all, unless I throw it a gear high under a lot of load, example: if I'm doing like twenty and aciddentaly throw it into 4th instead of second, and lay on the gas, then it'll ping a little, you just need to be careful.
Good luck, just remeber, it's better to run a little less compression, and not have to rebuild your motor, then get those couple of extra horses.
Later,
Aj
Old Nov 8, 2002 | 04:00 PM
alex b's Avatar
alex b
i was thinking the other night, and id like my compression to end up around 11:8:1 or so. i was thinking CTR pistons and a spoon headgasket would get me pretty close.
but of course if i could get away with 12:0 id probably go for it :wink:
Old Nov 8, 2002 | 09:42 PM
Aj's Avatar
Aj
Actually CTR pistons and a spoon head gasket, correct me if I'm wrong would have you well into the High 12 compression ratio range.
Keep in mind, the Civic Type-R may have a compression ratio of 11.5:1, but by using the same pistons, that doesn't mean that yours will also, you need to take into account the wrist pin height......
Also, when using larger dome pistons, and a thinner head gasket, you may run into piston to valve clearance problems. I'd look into it a little more if I were you......
Also, if you're running 92 octane, I'd say your right, and to be on the conservative side you don't want any more then like 12:1. I'd say, go mill your head thirty thousandths, that would accomplish what you want, for very little money, and without you having to go into your bottom end. Just remember to back up your timing if it's pinging, and keep in mind it may offset where TDC on your cams is.
Good luck, later!!
Aj
Old Nov 8, 2002 | 09:54 PM
alex b's Avatar
alex b
http://www.bseries.net/forum/viewtopic.php?t=2410&sid=7ba068104cff5d7ee5d28 06a2d5b12ab
thats the only reason i thought it would put me around 11:8
dont worry i dont just throw anything in my R and hope it works, i research a lot of aspects, thats why any help you guys offer up is really appreciated.
-alex
Old Jan 16, 2003 | 06:53 AM
2XS's Avatar
2XS
here is a spot that u can play with compression ratios with different internal mods
http://www.c-speedracing.com/howto/c...c/compcalc.php
how much less should u run compression if u might regularly get caught on 91 octane?
Old Feb 24, 2003 | 02:21 PM
JDMITR98's Avatar
JDMITR98
I love my ITR
Hey thanks- that is really useful! :wink:
Old Feb 24, 2003 | 05:01 PM
Aj's Avatar
Aj
well, realistically, on 93 octane I run 12.8:1, and I have a couple close friends in Cali that run 12.2:1 on 91 octane, so I guess it depends on how conservative and safe you want to be. On on 91 octane to be on the safe side, I wouldn't run any higher than like 12:1 compression, maybe a tad higher, but keep in mind, the lower octane and higher compression, the more timing you need to back off.
In any case, good luck,
Aj
