mugen exhaust
Old Oct 28, 2002 | 08:12 PM
itr's Avatar
itr
you know how the mugen exhaust necks out from the cat to the resonator at 2in , and then at the end of the resonator its a little bigger through out the whole system. can i cut the part before the resonator off and weld bigger piping on it or does the resonator start at 2in and gets bigger at the end of it???
Old Oct 28, 2002 | 10:57 PM
Aj's Avatar
Aj
Call King Motor sports, they are likely going to be the only people that will know the internal piping diameters half way down the B-pipe. not sure if they'll even waste the time finding out if they don't......
Old Oct 29, 2002 | 02:49 AM
Trey
Guest
Posts: n/a
it is 2" inside the muffler from the loop.
Not sure about the B-pipe
Old Oct 29, 2002 | 02:50 PM
Aj's Avatar
Aj
To be honest, what you propose sounds like more hassle then it's worth, why buy a very expensive exhaust just to hack it up????
Aside from that, you are going to change the flow characteristics of the exhuast, therefor changing the sound and performance aspects. In otherwords, why start with a mugen exhaust if you're not going to keep it the way it is.....
Look into the Hytech exhaust, it has the same twin loop design with a very stock looking tip, and from what I've been told is one of the best performing, if not the best, on the market.
Good Luck.
Aj
Old Nov 6, 2002 | 02:23 PM
Cosworth's Avatar
Cosworth
Every JDM cat-back exhaust system (except 1 or 2 straight through and under-the-axle design) will have small bottlenecks in the b-pipe. Why? Maybe it's to produce a desirable flow characteristic which can't be achieved by having a straight pipe design. Possibly, bottleneck is good for throttle response and/or midrange gains.
All in all, I wouldn't chop up Mugen exhaust to eliminate the bottle-neck. Mugen knows what they are doing... it's not there for aesthetic reasons.
Old Nov 7, 2002 | 04:21 AM
Trey
Guest
Posts: n/a
I wouldn't chop it up either but I don't think I would put it first on my list.
Or even 2nd. For the cost I can buy a lot more parts and I don't think the ITR exhaust is a huge weak point.
Old Dec 3, 2002 | 10:32 AM
TypeR882's Avatar
TypeR882
does your mugen exhaust make a vibration sound when driving?
Old Dec 5, 2002 | 01:27 PM
Austin's Avatar
Austin
Bottleneck in the b-pipe after the cat is to slow down the flow just after the cat to maintain the temperature of the car...
