45000 mile checkup....questions?
Old Oct 26, 2002 | 10:40 PM
ITR#158's Avatar
ITR#158
should i do all of these things or what......got the maintenance list from itrsport.com.
Inspect and Service Front Brakes
Inspect Rear Brakes
Adjust Parking Brake
Inspect Brake Hoses and Lines
Inspect Anti-Lock Brake System
Adjust Clutch
Inspect Power Steering System, Tie Rods, CV Boots
Retorque Suspension Mounting Bolts
Rotate and Balance Tires
Check Tire Pressure and Fluid Levels
Adjust Valves
Align Front and Rear Wheels
Change Transmission Fluid
Inspect Throttle and Transmission Cables
Flush and Replace Anti-Freeze (Not Required at 15,000)
should i get all of these things done to my car.......i did delete oil and filter change cause i do it myself.....i can rotate tires my self as well.....as for the other things should i get all of these things done to my itr ...????what should i do and what should i waste my money on? any suggestions or help would be appreciated!!!!!
Old Nov 6, 2002 | 02:31 PM
Cosworth's Avatar
Cosworth
Adjust/Bleed Clutch
Adjust Valves
I've cut out list of "services" that you should do regularly. The above list should be checked and maintained for sure.
I don't know what area you're located, but EVERYTHING listed on the service can be done by yourself after picking up a Helms manual from www.helminc.com
G'luck.
-Sean
