Adjusting TPS???????HELP??????
I'm trying to adjust my TPS sensor to fix a screwed up Idle, but it appears the bolts holding it on have the tops of them cut off from the factory, and I can't quite figure out how to loosen them without damaging something. Does any one know if there is some special tool for removing the bolts, or some other way of adjusting the TPS????????
Aj
Aj
Since I switched ECU's, it changed the voltage on the TPS, which when I talked to Hondata, they said, I needed to rotate it until I got it to exactly .45V.
Though it appears to be rivited on, it's not, the studs that are there instead of having nuts, they have snap washers, but they are threaded, so I'm sure there's some way to get it off without ruining it........
Dunno, if anyone has had this problem, let me know!!!
Aj
Aj
