Double Clutching
Old Oct 20, 2002 | 10:58 AM
pUrExTc's Avatar
pUrExTc
殺生丸
I just learned how to double clutch last night. I must say, it does feel like you're going faster. But I came to think, would my RPM be there if I'm not double clutching, or does double clutching really make you faster? It certainly feels faster, and sounds pretty cool. what permanent damage can be done though? I'm guessing it's all stuff involving your gears, flywheel, etc. My other friend with his Civic does it all the time, and says nothings wrong with his car...and he's been running it hard for about 3 years (everywhere he goes, yes, he is the definition of Rice-Boy).
Old Oct 20, 2002 | 10:46 PM
B2FiNiTY's Avatar
B2FiNiTY
Dude...how are you double clutching? It does not make your car go faster.
Double clutching is
1. Clutch in
2. shift to neutral
3. clutch out
4. rev-match
5. clutch in
6. shift
All it does is do the work that your synchros are doing. It makes shifting smoother but at the same time slower and practically worthless unless you have a car without synchros or they are busted.
Keep the F&F stuff in the movie where it belongs.
Old Oct 21, 2002 | 04:09 AM
joe s's Avatar
joe s
From what I gather, double-clutching is not as necessary with today's modern gearboxes as it was when synchros weren't a given. It definitely takes more time so really couldn't be faster. I do a 'lazy man's' double clutch ie downshift into the next gear and blip the throttle before letting the clutch out. This matches revs as well as putting less strain on the gearbox. Sounds cool, too
Old Oct 21, 2002 | 02:19 PM
bbqman's Avatar
bbqman
Double clutching in todays cars is real rice boy stuff. Only good for posing and really not required.
However, heel and toe down-shifting is imperative for good , sound performance driving. It is a must for racing!
Practice it on the street, apply it on the track.
Nuff said.
Old Oct 21, 2002 | 11:09 PM
pUrExTc's Avatar
pUrExTc
殺生丸
OK...so can someone please tell me what i learned then (obviously it's not double-clutching...it's just termed that way among some of my friends). Here's what I was taught to do, and yes, it does make a bit of a difference.
1. press your clutch in and let it out while racing (already in gear). holding the gas in the entire time.
2. this can be done before vtec (recommended to me at 3000 RPM), and/or after VTEC (recommended to me at 7500 RPM).
Is this an actual technique? or what is this? try it...it works. if you're afraid to do it in your itr, try it in one of your POS rides...like one of your buddies cars or something.
Old Oct 22, 2002 | 01:34 AM
B2FiNiTY's Avatar
B2FiNiTY
This is like launching but while moving. Pretty dumb if you ask me...not a racing technique I know of... :roll:
Old Oct 22, 2002 | 04:32 AM
bbqman's Avatar
bbqman
This is absolutely a last chance technique used when all else goes wrong.
If you screw up an entry to a corner, then realize you are in the wrong gear, a last resort technique to build rpm's so that you don't have to down shift mid-corner, would be 'fanning the clutch'.
This sucks because it's kills the pressure plate etc etc etc.
Don't try this at home kids!!!
Old Oct 22, 2002 | 07:33 AM
pUrExTc's Avatar
pUrExTc
殺生丸
so the correct term for this is "fanning the clutch" then?
Old Oct 26, 2002 | 06:18 PM
ITR#231's Avatar
ITR#231
I have to respectfully disagree with this. I double clutch nearly every downshift unless I'm going as far as 4-3-2 where there simply isn't time if the brakes are working properly. Syncros or not, matching the RPM in neutral is much smoother for me and I'm much less likley to upset the car. One less thing to think about as you enter the corner. The only time I won't double clutch is for an ugly 2-1 shift while autocrossing, mainly because the car is going to be upset a little anyway. Fortunately, I haven't ever had to do that on the track.
Old Oct 28, 2002 | 04:26 AM
bbqman's Avatar
bbqman
Is it posible you might be mistaking double-clutching for 'heel and toe'.
Like you described and I agree, to properly set yourself up to exit a corner, racing or other, matching the engine speed with the tranny is a must.
If it is done under braking, the method you are using is called heel and toe. You are blipping the throttle to match rpm's so that there is a seemless transition between gears.
Double clutching is for trucks and vehicules with no synchros, who have a hard time finding the next gear and engaging it smoothly.
This method is a big waste of time for racing and is not used with current cars.
