H.I.D.
Old Oct 21, 2002 | 11:52 AM
B2FiNiTY's Avatar
B2FiNiTY
Very well put. 6000K + kits do not put out as much light as the 4300K.
The reason you see some OEM HID have different colors is because of the housing that reflects different colors. You'll notice that it's not the same color all the time like those 8000K barney purple kits.
Old Oct 21, 2002 | 01:57 PM
itr's Avatar
itr
aj
what color bulb do you have? and what kind of bulb is it? what kit do you have that retails 1200 because the most i have seen the Hella kit for it like 600
Old Oct 21, 2002 | 09:50 PM
Aj's Avatar
Aj
The bulbs that I have shed a sort of bluish violet light, but a lot more white then purple.
As far as you having seen the Hella kits for like $600, some people pawn off kits that have Hella balasts, as the Hella kit, but the only place you can buy the full Hella kit, is from Hella, or an authorized retailer, in which case, they are special order only. Hellas suggested msrp is is like $1219.98 or something, and wholesale on the kit is like $745, depending on your buying status from Hella.
The real Hella kit comes in a blue and yellow box that says "HELLA" on it, anything else is not the real Hella kit and may just use Hella balasts, such as the philips kit.......
Aj
Old Oct 22, 2002 | 01:36 AM
B2FiNiTY's Avatar
B2FiNiTY
Just to throw out some additional info:
The most common "kit" out there right now is the so called Philip's kit which contains a philip's ballast and Osram bulb. It is still a good kit but it's not exactly what is advertised.
True Philip's kit is Philip's bulbs and ballasts.
Old Oct 22, 2002 | 05:36 PM
itr's Avatar
itr
what site can i go to to look for hella kits. ive searched the net and dont find an can any one help
Old Oct 22, 2002 | 05:45 PM
Aj's Avatar
Aj
Um, DUH, have you tried going to Hella's web site???? :idea:
Old Oct 22, 2002 | 08:18 PM
itr's Avatar
itr
in hellas website i dont see their hid kits
Old Oct 22, 2002 | 10:05 PM
Aj's Avatar
Aj
They're there some where, thats where I found them. Dont remember the web address, but if I bump into it again, I'll post the link.
Good Luck, Sorry I couldn't be of more help......
Aj
Old Oct 31, 2002 | 08:58 AM
STC's Avatar
STC
I bought the 4300k Phillips kit from Trevor @ Visualdynamics.
Awesome customer service.
Old Dec 11, 2002 | 02:38 PM
JDMDC2turbo's Avatar
JDMDC2turbo
How much did you get the 4300k? And can you give the website. Thanks
