compression test results 95 se
Old Mar 22, 2004 | 05:50 AM
Driver's Avatar
Driver
slow lane cruiser
Default compression test results 95 se
Hey if any one has the time or inclination,
i got #1-180 #2-170 #3-170 #4-180
Ijust read a post in the library that suggests possible head gasket wear
with those kind of numbers. the cars got 120,000 on it
runs lean, am I alright here or should I perhaps look into a new gasket, I need to adjust my valves soon anyway.
Thank you HAN I know that i know nothing which at least puts me ina position to learn
Old Mar 22, 2004 | 06:35 AM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
Hmm... I honestly don't remember the interval for replacing the head gasket. Knowing Honda parts, I'd bet it will hold until at least 150K at a minimum...:thinking:
I've got Monday morning brain; pardon my ramblng. I'll look up the stock comp numbers and get back to you later today. h:
Old Mar 22, 2004 | 06:48 AM
Driver's Avatar
Driver
slow lane cruiser
Thank you NorCal- I appreciate your time
i'm pretty shur the stock comp numbers should be either 185psi or 199psi for my engine Iwas just curious as to my engines health being that i am just learning
thank you
Old Mar 22, 2004 | 07:49 AM
reno96teg's Avatar
there is no interval for replacing the head gasket. that should only be done if there's enough damage/wear to warrant it.
those compression numbers are fine. the 170s may indicate minimal head gasket wear between those cylinders, but definitely nothing to worry about.
driver, if you're referring to the valve cover gasket, that has nothing to do with your issue of running lean. yes, you should replace it every time the valve cover is removed (i.e. when you adjust the valves) but all that gasket does is keep the valve cover sealed.
just to make sure you're clear on this, valve cover gasket does not equal head gasket. your issue of running lean is being caused by something else, i'm almost sure of it. when's the last time you replaced things like the fuel filter, spark plugs, etc.?
Old Mar 22, 2004 | 12:34 PM
TheOtherDave™
Apathy Kills
I stand corrected. Thanks reno. :goodjob: I was suffering from some serious brain fade at the time.
Old Mar 22, 2004 | 12:40 PM
newgsrdriver's Avatar
newgsrdriver
What makes you think youre running lean first of all?
The comp #'s look just fine.
Old Mar 22, 2004 | 01:41 PM
Driver's Avatar
Driver
slow lane cruiser
hey thank you for your replies everyone, I truly do appreciate it.
I have done plugs wires cap rotor fuel filter air filter and assorted sea foaming all recently.
I think:thinking: I am running lean because my plugs are consistently white and alittle yellowed on the insulator whenever I change/check them
which I believe means alittle hot, so hot+lean kind of go hand in hand I assume
but you say the numbers arent bad so this is comforting
My car does feel ok to me but I'm picky maybe too much
sorry for being unclear I should have had too questions there
valve+head gaskets two different things huh I have much to learn
but as far as my symptoms indicate am I running lean?
If not that would be a great relief thank you for listening guys
Old Mar 22, 2004 | 01:58 PM
reno96teg's Avatar
hmm.. perhaps you're just misreading the plug. which one do your plugs look most like?
Old Mar 22, 2004 | 09:35 PM
Spec R's Avatar
Spec R
thats right where they should be for a b18b1.
dont be discouraged by the 220's that GSR's put out.
DB Squad
Integra Forum Moderator
Old Mar 23, 2004 | 04:50 AM
Driver's Avatar
Driver
slow lane cruiser
Thank you guys, Reno- my plugs look like two of those photos
on the firing end normal, but on the boot end is where i find the yellowish burnt look
is that normal? BTW-I use the oem ngks
