ITR Pistons fit in b16 block?
Old Mar 10, 2004 | 11:24 PM
Civic_GSR's Avatar
Civic_GSR
Chop Shop Street Team
Default ITR Pistons fit in b16 block?
I was just wondering if ITR pistons could fit into a stock b16 block. Because b18c5 motor is 1.8L and b16a2 is 1.6L. Doesn't that mean the size of the combustion chamber is larger therefore larger pistons?
Old Mar 10, 2004 | 11:35 PM
DB7 2.0's Avatar
DB7 2.0
Banned
it fits. the difference in the engine size comes from the stroke which is measured by the crank rotation.
Old Mar 10, 2004 | 11:50 PM
Kai's Avatar
Kai
Rotorphile.
Both have 81mm bores, simple swap.
Old Mar 11, 2004 | 12:39 AM
qtiger's Avatar
qtiger
They'll actually lower your compression though. Try CTR pistons instead.
Old Mar 11, 2004 | 05:24 AM
shivers's Avatar
shivers
Moderator Alumni
While CTR pistons are a good option, they need to be used with caution. The piston to deck clearance is substantially reduced, so the engine should be clayed to ensure you won't have any valve to piston contact. The stock b16 rod ends must also be machined (1mm off each side) to accept the CTR pistons. It can be done and has been done, you just need to make sure all your specs/measurements are correct to avoid any problems.
2005 s2000
Old Mar 11, 2004 | 10:17 AM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
Right, I was about to mention that the rod ends need 1 mm machined off each side around where the piston pin goes through them. I believe that's also the case with B17 rods, not sure about B18A/B ones.
Along with what you mentioned about the clearance issues, for those who are unaware the CTR uses a B18C block with a shortened stroke hence why it doesn't have issues with the piston-to-deck clearance.
Old Mar 11, 2004 | 01:02 PM
Kai's Avatar
Kai
Rotorphile.
Rod milling does still apply with B18A/B blocks, that's where I first heard about the operation.
LOwrestling2001
May 28, 2003 10:31 PM
LeftCorner
Sep 17, 2002 03:51 PM
ghost
4
Aug 3, 2002 09:18 PM
MF10
Jun 22, 2002 04:53 PM
