Help with wheels for a 91 LS
Old Feb 19, 2004 | 11:08 AM
Keytwo's Avatar
Keytwo
*Bling Blang*
Default Help with wheels for a 91 LS
I have a 91 Acura Integra 3-D LS, and I was looking for new rims to replace the ugly stock ones.
The ones I currently have are 14" (not sure of the width or other specs).
My question is, what would be the optimal offset and size if I want to upgrade to 15" wheels? Also, what other changes need to be made (speedometer?).
Here is an ebay auction I was looking at: http://cgi.ebay.com/ws/eBayISAPI.dll...gename=rvi:1:1
Are those reasonable, or is the offset/etc. incorrect?
Thanks in advance.
Old Feb 19, 2004 | 11:26 AM
randomtask77's Avatar
randomtask77
Wanderer
The specs that are given for those wheels are ideal for your car. You shouldn't have anything to worry about getting those wheels for your car.
Old Mar 1, 2004 | 10:13 AM
Keytwo's Avatar
Keytwo
*Bling Blang*
What would be the ideal offset on 17 X 7.5 rims? Is +45 ok?
Old Mar 4, 2004 | 11:57 AM
Keytwo's Avatar
Keytwo
*Bling Blang*
These are the ones I was thinking about getting? Does anyone know if I will have rubbing or any problems with +45 on this size?
http://www.revolutionsmotorsports.co...s/dept_69.html
Old Mar 4, 2004 | 12:44 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
I wouldn't go any larger than 16" wheels personally.
As for maintaining the outside diameter of the tire, that has to do with tire sizing more than wheel sizing. Here's a good tire size calculator that will let you compare two sizes: http://www.miata.net/garage/tirecalc.html
Your stock tire size is 195/60-14.
Old Mar 4, 2004 | 12:54 PM
ragerized's Avatar
ragerized
dc4 ownerages
haha, knockoff ssr's
Old Mar 4, 2004 | 02:13 PM
Keytwo's Avatar
Keytwo
*Bling Blang*
Do you say 16" wheels for appearance, performance, or economic reasons?
The 16's that I like have a +40 offset and are 7" wide. Is that OK?
Old Mar 4, 2004 | 06:53 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
All three.
I mean, it's not like 17" wheels are going to seriously affect the way your car drives in a negative way. But, they look a bit too big unless you have a body kit, they are generally heavier, to get a light-weight one you have to spend more, the tires are more expensive, and the tire sidewalls are really skinny.
A 7" wide wheel with a +40 offset should fit no problem. For tire size you want either 205/45-16 or 215/40-16.
Old Mar 4, 2004 | 07:51 PM
Keytwo's Avatar
Keytwo
*Bling Blang*
All three.
OK. Thanks a lot. You've been a huge help.
Old Apr 8, 2004 | 11:08 AM
Keytwo's Avatar
Keytwo
*Bling Blang*
I might be buying some wheels off a friend. They have been on an Integra (I'm unsure of the model) for a few thousand miles, and a Nissan Maxima for a short while as well. Should this be a problem? I've heard that the car that the wheels came off of can be a factor.
Also, if I'm switching from 195/60-14 to 205/40-17 is it neccessary to do an alignment? The difference in radius is approximately 1/10 of an inch.
Barry WY
Jan 5, 2003 07:20 AM
PoweredbyHonda
Oct 18, 2002 09:56 AM
RKV
Accord
15
Oct 15, 2002 02:05 PM
RiteshP24
Accord
15
Aug 26, 2002 04:54 AM
mookiestic
Showroom
Jul 9, 2002 11:49 AM
