Bypassing coolent?
Old Feb 18, 2004 | 03:43 PM
integsracer's Avatar
integsracer
Default Bypassing coolent?
a friend of mine told me that if you bypass the coolent so that it doesnt run through your intake manifold, it would keep cooler, and the only reason its there is for warming up. there is a valve that senses temp. and makes it idle higher when its cold i guess. he said i might make the idle fluctuate a little more. does anyone know anymore about this? and how to do it on a gen3 integra gsr?
-jon
Old Feb 18, 2004 | 03:45 PM
g2tegls's Avatar
g2tegls
MR, ftw
coolant runs through the intake manifold? :thinking:
Old Feb 18, 2004 | 04:36 PM
Epoch's Avatar
Epoch
CHRISTMASTIME IN IRAQ
Yep... the intake manifold actually does have an operating temperature, and the coolant helps keep it there
-jon
Get a Hondata intake manifold gasket... Unless you're running a pure-race app, then you will want the coolant running through your manifold to warm it up to the proper temperature... The Hondata intake manifold gasket will help eliminate the excess heatsoak from the block, where most of the negative heat comes from...
Old Feb 18, 2004 | 11:20 PM
hondatech's Avatar
hondatech
Honda tech/eprom hackr
If you're talking about the inlet/outlet in the actual throttle body not the intake manifold(which i think is what you're friend is talking about) cause I've seen this topic and articles many times before, It's to warm the intake charge of air/fuel on cold starts. It helps atomize the air/fuel mixture better when it's cold. If you bypass it which I don't recommend, you might get a cold start issue or idle issue. It's not even worth the trouble because there is no real gain, you'll never feel it. gain's cost money and nothing is free. this is really true for hondas. i think the going rate for hondas is around 100 a 1hp gain these days, lol
Old Feb 19, 2004 | 11:48 AM
integsracer
ok,thanks guys.
Rustle15
11
Apr 16, 2005 11:40 PM
slammmedintegra
15
Feb 6, 2003 10:39 AM
