'98-'01 OEM Foglight question.
I recently purchased the OEM Raybrig foglights, the round ones with brackets for the teg, but I am having a little bit of a problem. I have found that Acura has discontinued making the foglight harnesses. I know the switch still is being sold at select places but I am not sure what to do about the harness. Does anyone have the part number of the harness or can direct me to where I can find more info on this matter. Also, if you might have the harness lying around or know of a place I could contact to purchase it, i.e. salvage yard, Acura dealership, auto body shop, etc. Also, has anyone taken alternate routes to installing the fogs, for instance aftermarket harness setup. I would like to keep the installation as clean as possible. Thanks for your help.
I'm assuming a generic harness (made by Pilot or similar) will work, and I'm sure you can adapt the OEM switch to it as well. You could also tie them into your headlights, which would make them turn on as soon as your headlights do.
chuanger
Accord
6
Feb 12, 2004 04:19 PM
Howitt
Apr 25, 2003 03:16 AM
